Results 1 to 4 of 4
Thread: DTC I've never seen
    May 2008
    Default DTC I've never seen
    What is a p046C HI? Im getting this but there is nothing in the DTC library. THX!
    It is an EGR code.
    Might be time to update your software, it's certainly defined in the V7.5.4 download here -
    http://www.efilive.com/download.aspx
    Senior Member DmaxHawk's Avatar
    Apr 2008
    Any definition to the code?
    Off the top of my head no. If you search for the fault code in the DTC list that will give you a description, likewise, in the scantool when it shows you the current DTC's set the description will also be there.
