Results 1 to 4 of 4
Thread: Help COS5 Semi OL STFT ?
    Senior Member RandyWS6's Avatar
    Jan 2005
    Exclamation Help COS5 Semi OL STFT ?
    Im running in semi OL and my STFT's don't start reading till 180*F , what temp are you guys stft start reading. What it is, my car is running rich at start up till i get to 180* and then my stfts take over and controls my fuel trims to 14.6 afr. I am running COS-5 and done the auto VE and they are around .99 to 101 ,that the best i can get it here in KY ,some days its cool and others are hot.
    And after the car is wormed up , it run grate ,but if i shut it off for any amount of time ,and then restart it and the AFR is at 14.6 for about five to ten sec.Then it will go extremely lean (19) on my WB and will not take fuel. Like the car is dumping fuel and the O2's are pulling fuel to try to lean it back out , then after about ten sec. or so it will go back to normal and runs perfect all day long, until i shut it back off. Now this only does this after the engine is up to temp. What is causing this. I also had this problem before i went to COS5 and with a massair. Do you think if i had my STFT to come on sooner this might help. If so how would i do this.
    Thanks, Randy
    2000 WS6 TransAm-M6 LS3 forged 422 cid. 4L80 FMVB ,4:22 Ford 9"-35 spline axles
    2014 C7 3LT-Z51 Corvette Stingray M7 , A&A Supercharger , Kooks 1-7/8" long tubes & X Pipe 615 rwhp & 560 rwtq
    http://community.webshots.com/album/259987907DcztOG
    Jan 2007
    Have you changed/adjusted A0008?
    Jan 2005
    yes i have, I did the cold idle from 50* (1.48) to 158*(1.03)
    Jul 2003
    My issue with STFT is that they go to 0 with regularity.. they could be +8% and jump back to 0 and back to 5 or 6% or what not...
    They fluctuate too much..
  1. stft (your input)
    By drdarthinvader in forum Custom Operating Systems
    Last Post: April 23rd, 2010, 10:49 PM
  2. stft problem
    By drdarthinvader in forum Gen III V8 Specific
    Last Post: June 29th, 2009, 12:22 AM
  3. COS5 semi open loop ?
    By RandyWS6 in forum Gen III V8 Specific
    Last Post: April 10th, 2008, 03:38 PM
  4. stft
    By 69camaro5speed in forum Custom Operating Systems
    Last Post: April 8th, 2008, 02:39 PM
  5. COS5 question on STFT's
    By onfire in forum Custom Operating Systems
    Last Post: July 22nd, 2007, 01:16 AM
