Results 1 to 6 of 6
Thread: Mafless tuning problems
    Aug 2008
    Default Mafless tuning problems
    I am new to EFI Live. I have a 1972 chevy pickup with a basically stock LS1. i am trying to set it up with no MAF and have no idea where to start. can anyone help
    Hi kmidkiff,
    Welcome to the forum...
    What year/model was the donor vehicle, and how much of it did you transplant...?
    Joe
    Aug 2008
    The LS1 came from a 2001 Camaro, i am using a painfull (i mean painless wiring Harness) and the stock ECU. The truck is basically a show truck sponsored by Professional Products. It dosent have to make a lot of power but it does have to move around on its own power. I will not be able to dyno this vehicle because the suspension system will not allow us to strap it down. So basically i need to delete the MAF, Create a Idle, Base, and Mid range tune. If this is at all possible.
    KMidkiff
    NSN Performance
    Jan 2005
    Welcome to the forum kmidkiff! The links in my sig should help get you going.
    Oct 2007
    ok, helps a bit. Also, how is your speedo hooked up? Is it still all electric, or did you get a combo electric/cable setup?
    1. You will need to turn anti-theft off, G1201
    2. I would advise to try and get your speedo stuff close. It affects several things(shiftpoints, cracker and follower, etc).
    3. Under C6001.. Turn P0101, P0102, P0103 to "C"
    4. Under C6002.. Turn same options to "NO MIL".
    5. There will be many other options you will want to turn off under them to charts(6001/6002) like rear o2 sensors, purge system, etc.
    6. Since you are a mostly stock setup, I doubt you will have to worry to much about idle learn or changing the ve. But I would give them a quick glance over.
    BTW, I wouldnt mind seeing some pics of the project. Have a 67 c10 here
    11 Silverado
    08 Sierra
    91 RS with 350 TPI and 411 ECM
    Aug 2008
    Thanks for the support, The trucks not in my posession yet but will be in two days. i will get all the speedo info then. Im just getting ready for it. Ill post some pics on Monday.The truck has won numerous shows in texas and is getting a 9 page spread in truckin magazine next month. the car had a carbureated small block in it until we drew in some sponsors and they wanted the LS1. Not so bad just a little bit of a learning curve
    Thanks again
    Kmidkiff
    Houston, Texas
    NSN Performance
  1. 09 LMM tuning problems
    By rgullett83 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 15th, 2009, 05:44 AM
  2. problems tuning need help
    By 2000zrocks in forum Gen III V8 Specific
    Last Post: April 30th, 2008, 09:43 AM
  3. mafless tuning question
    By The Alchemist in forum General (Petrol, Gas, Ethanol)
    Last Post: November 2nd, 2006, 07:55 AM
  4. Tuning mafless oem operating system
    By Dlong in forum General (Petrol, Gas, Ethanol)
    Last Post: May 13th, 2006, 03:38 PM
  5. TUNING MAFLESS ?
    By Last Call in forum General (Petrol, Gas, Ethanol)
    Last Post: March 31st, 2005, 02:05 PM
