Can you take a look at my tune. I have been having some rough idle issues while in park. Thanks for any help. Here is my tune.
What is your plug gap...?
Is your coolant level staying constant...?
the plug gap is set at .40. The coolant is fine now that i have done the z06 cam swap. I replaced the water pump seals and it doesnt leak anymore. I upped the idle 75 rpm's or so, and it seemed to help. Just wondering why it sounded like a 110lsa cam or such when at 550 rpm idle. Checked all the TB and intake tube, MAF and everything looks good. Looked for any vaccum leaks as well.
cory
Stock Z06 idle is 800 rpm.
Did you get a double click on the plug wires to the coil packs?
2003 red vert
Mods:
LPE 100mm MAF
RPM Level 6/4L60e trans
3.42 gears
Yank SS3600
1-7/8" AR headers
Z06 exhaust
470rwhp 437rwtq
may be O2 switch point {4105}
from your tune, change to stock values
