Results 1 to 5 of 5
Thread: Ideas? Between reflashes I have to reboot laptop...
    Jun 2005
    Default Ideas? Between reflashes I have to reboot laptop...
    I fire up the laptop, plug in the flashscan, click on tune, read pcm, tune it, reflash and all is good. When I make a second set of changes it will kind of try to connect, almost gets there and then I get the pop up window that says cannot communicate with flashscan. The only way I can get it to reflash again is to shut down the program, turn off the laptop, and start all over again.
    This makes tuning take a LOOOONG time.
    Any ideas??
    '71 chevelle
    Twin turbo ls1
    1000 HP 93 octane street car!
    96 lb injectors
    Nov 2006
    look into your drivers or firewall.
    Has anything changed on your set up from when you first started tuning?
    New laptop, new Windows version? Are you using a V1 or V2?
    P.S - How is the Chevelle going?
    Jun 2005
    The v2 and laptop are new. I just finally kind of got it working but it does this. I will have to check the firewall.
    I sold the Chevelle, but have a twin turbo GTO in the works. Wont be as crazy as the chevele, but will still make at least 750 rwhp on pump.
    '71 chevelle
    Twin turbo ls1
    96 lb injectors
    Oct 2003
    Do you have both Scan and Tune open?
    PowrMax Performance
    100 mm PowrMAF
  1. V2 will not reboot
    By TRAV in forum FlashScan V2
    Last Post: June 11th, 2010, 05:12 PM
  2. T43 Ideas
    By oztracktuning in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 9th, 2009, 02:12 PM
  3. E67 2.4 LE5 With VVT any Ideas?
    By Quasimotor in forum E37, E38 & E67 PFI ECM's
    Last Post: January 31st, 2008, 11:03 AM
  4. V2 stuck in reboot after 2.05.10 FW
    By Treurentner in forum FlashScan V2 BB Logging
    Last Post: December 3rd, 2007, 09:18 AM
