If nobody has done it before, somebody has to do it....
1997 Tahoe 2dr 4WD
2002 Alfa Romeo Sportswagon 2.0 JTD
1982 Deutz Intrac 2004A
2003 friesian Horse " Henry"
You need to be a bit more specific, need an OS, not a year model (too many OS's per year).
12597121 86ynauk16194d88a
12605897 YNAU
These are the No on the ECU. originally it came out of an Avalanche: 3GNEC12047G152683 RPO LMG, but 2wd
I need an LMG .tun file for a '07 4wd.. is that all you need Ross??
Harald
1997 Tahoe 2dr 4WD
If you can find a VIN on the internet that is LMG 07 4WD I can get you the correct ECM file.
This one is a '07 Tahoe 5,3 LMG:
1GNFK13027R336350
If you could email me .tun file and correct operating system to haraldschoener@yahoo.de that would be great.
If you have the correct .tun file for the 4L60E tranny for the above VIN you should send this too.
Thanks a lot in advance
Harald
1997 Tahoe 2dr 4WD
Did you find something suitable, Ross?
1997 Tahoe 2dr 4WD
Eventually..........
Thank you Ross for the tun files. Do I need a different OS to use these files? My OS in the ECU I have was posted somewhere in the beginning of this thread.
Harald
1997 Tahoe 2dr 4WD
Yes, those two OS's match for that year SUV and that engine combo. If you existing ECM and TCM don't have that they won't work.
Ok Ross, that sounds good to me.... this is done.
Did you think about :
Looks like that is a real VSS output indeed.
Did you actually wire it up?
However, there is a parameter that appears to be a enabler for that output. If it is activated then something else might stop (I'm not sure).
I'll need to add the enabler in to the calibrations.
Are there any cal files avaiable which support that VSS output enabler..?
Harald
1997 Tahoe 2dr 4WD
