Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: tune help, very high idle
    May 2008
    Default tune help, very high idle
    i have no idea whats goin on here, its idleing at like 2400 and wont go down. IAC steps are at 0 at idle. The car has a 224 cam, headers/ypipe/catback, ls6 intake, slp lid/kn filter. Ive replaced the IAC already and no change.
    Lifetime Member Biggsy's Avatar
    Jan 2007
    Vacuum leak? (would be a big one)
    Throttle stop adjusted wrong?
    Is it a std throttle body?
    Dave.
    Senior Member Sid447's Avatar
    Jul 2005
    Quote Originally Posted by BROKE View Post
    Who did your tune.
    There are parameters in there from an A4 car.
    Also the Timing in B5932, 5933, 5913 and 5914 is abnormally high.
    B4307,4308 are too high also.
    If you are able, flash in a 2002 ZO6 tune and take it from there. GM spent a long time validating these factory tunes and the ZO6 tune should work sufficiently well enough for the mods you have on the car atm.
    Nov 2006
    {B4307} maybe set a little higher than needed.
    have you checked for a vacuum leak?
    Jun 2005
    Quote Originally Posted by Sid447 View Post
    Who did your tune???
    Holy $h!t!!! You weren't kidding.
    Whoever did this tune....wow!
    A little 224 cam doesn't need anywhere near 43* of timing to idle. Nor should it be running 32* at WOT unless maybe you're fighting some serious altitude.
    May 2008
    Quote Originally Posted by SSpdDmon View Post
    im not sure who did the tune, it came with the car. It seems to run balls rich and stutter at WOT.
    May 2008
    i figured out the high idle was cause by pin 79 on the red plug being pulled out, it still runs shitty though.
    May 2008
    lol, no altitude issues in austin
    Jun 2005
    stick or auto?
    May 2008
    stick or auto?
    stick
  1. High idle after new MAF
    By Chriskaw7r in forum Gen III V8 Specific
    Last Post: May 2nd, 2011, 05:43 AM
  2. High Idle
    By lucky1 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 1st, 2008, 04:14 PM
  3. High Idle
    By y2kws6 in forum Vortec V6/V8 Specific
    Last Post: June 1st, 2007, 02:18 PM
  4. idle ltft high after auto tune
    By 69camaro5speed in forum General (Petrol, Gas, Ethanol)
    Last Post: February 26th, 2007, 01:29 PM
  5. High idle when car moving
    By tazinhawaii in forum General (Petrol, Gas, Ethanol)
    Last Post: May 5th, 2006, 07:01 PM
