Results 1 to 3 of 3
Thread: V2 Connecting problems
    Oct 2006
    Default V2 Connecting problems
    Tried connecting with V2 on my friends 2000 Chevy S-10. V2 didn't light up. Veried that V2 still works on my 2000 silverado. Would appreciate any input.
    Rey
    Oct 2004
    If the device was connect to the S-10 via the OBDII cable and did not power (and still works on your vehicle) it is simply due to the device not getting power from the vehicle. This is pretty interesting as I would have expected the OBDII connector on the vehicle to be identical.
    Have a look at the 'Bench Harness Tutorial' available under the 'Help->Tutorials' menu option of the Scan and Tune tools. It looks like pin 16 supply the 12V power which you might want to verify with a multimeter.
    Andrew
    EFILive Crew
    Oct 2006
    Tordne,
    Thanks, we checked the fuses and the cigarette lighter fuse was blown. Replaced and V2 connects.
    Rey
  1. RR not connecting..need help
    By superspeed in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 29th, 2009, 11:50 AM
  2. New help connecting to RR
    By 99ss in forum RoadRunner Real-Time PCM Emulator
    Last Post: August 25th, 2007, 10:57 AM
  3. Problems connecting with the RR
    By 5.3 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 13th, 2007, 11:55 AM
  4. connecting lc1 to v2
    By mr.prick in forum FlashScan V2
    Last Post: February 8th, 2007, 12:46 PM
  5. problems connecting help
    By 87gmc in forum General (Diesel)
    Last Post: January 30th, 2006, 05:38 PM
