Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Tutorial: FlashScan V2 Serial Wideband Logging
    Unknown Zone TAQuickness's Avatar
    Jan 2005
    Default Tutorial: FlashScan V2 Serial Wideband Logging
    Enjoy...
    Jan 2005
    If you get an error while trying to drag and drop files, try formatting the file system
    If the WB PID's are X'd out in the scan tool, you will need to validate PID's while connected to the vehicle.
    An updated tutorial will be posted in the next few days with these items in context.
    Aug 2007
    Can you tell me where the option.ini file is???
    Nov 2006
    Quote Originally Posted by cyclerage View Post
    C:\Program Files\EFILive\V8.1\Programs
    Apr 2009
    Hi all,,,
    in the PDF file it says Innovative Motorsports Dual Channel LM-2 I got the single CH' would it work?? thnx
    Member 427's Avatar
    Dec 2007
    Cool
    Quote Originally Posted by A.O.A View Post
    Hi all,,,
    Yes but i will double check for you
    Jun 2007
    What are the pros and cons of hooking up the wideband through serial vs analog?
    Senior Member MyM8V8's Avatar
    Aug 2008
    Quote Originally Posted by ryans1000 View Post
    I used Innovate LC-1's and it was a breeze using serial connection. It's just plug and play. You'll need to either make a cable or get one from TAQuickness. Well worth it IMHO.
    2005 HSV Maloo Ute, HKE 457ci Stroker LS2 E40, TFS 245's, 255/263 Hi Lift HUC, FAST LSXr 102, NW Billet 102 TB, FLT Level 7 4L65E, CircleD 4200 stall, Duspeed OTRCAI - Mafless, DF 1 7/8" LT's, 3" DiFilipo Duals, Serial LC-1 WB's
    "An Old Dog learning new tricks"
    Jun 2007
    Quote Originally Posted by MyM8V8 View Post
    So your saying the benefit of serial over analog is its quicker to install?
  1. Wideband serial update
    By Blacky in forum FlashScan V2 BB Logging
    Last Post: September 9th, 2010, 09:13 AM
  2. Serial Wideband AFR & B3601
    By WeathermanShawn in forum General (Petrol, Gas, Ethanol)
    Last Post: April 25th, 2010, 04:51 AM
  3. log serial wideband
    By b18cls1 in forum Black Box Logging
    Last Post: February 12th, 2010, 03:46 AM
  4. Can't log serial wideband anymore
    By white01ss in forum Tutorials
    Last Post: October 28th, 2009, 08:39 AM
  5. serial wideband
    By articSS in forum Black Box Logging
    Last Post: December 19th, 2008, 06:04 AM
Tags for this Thread
