Enjoy...
Enjoy...
If you get an error while trying to drag and drop files, try formatting the file system
If the WB PID's are X'd out in the scan tool, you will need to validate PID's while connected to the vehicle.
An updated tutorial will be posted in the next few days with these items in context.
I'm using the AEM UEGO WB connected through serial Comms.
I got the new Calc.pid.txt downloaded and coppied to the right folder and it appears in the PID list. I selected it and connected to vehicle and the Comm. port for the WB. Then validated the PIDs and it still is X'd out. Any ideas?
Thanks,
Branden
Can you tell me where the option.ini file is???
Hi all,,,
in the PDF file it says Innovative Motorsports Dual Channel LM-2 I got the single CH' would it work?? thnx
What are the pros and cons of hooking up the wideband through serial vs analog?
