Results 1 to 2 of 2
Thread: LBZ Calibrations
    Aug 2008
    Default LBZ Calibrations
    Hello,
    I am trying to load tunes into my LBZ and it states the tuning cal and the ecm cal do not match, also I noticed in program files/eflilive/calibrations, that LBZ is not in there?
    I am running version 7.5.4 (Build 66)
    Can you please advise?
    Thanks Much!
    Cory
    Hi Cory,
    The warning you are seeing means you are trying to program a tune from an ECM Operating System that does not match what is in your truck. This can't be done.
    Programming in a tune from another truck can cause issues anyway as things like the A/C type are specific to each truck. Whilst it might not break anything it will cause some oddities to occur.
    Can you elaborate on the second point?, LBZ not in there? If you mean the calibration folder then no it won't be, the LBZ/LMM are in a folder called E35.
  1. Rev limiter and E38 calibrations
    By 4wheelin in forum E37, E38 & E67 PFI ECM's
    Last Post: December 10th, 2009, 06:58 PM
  2. MAF calibrations
    By pullincrazy88 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 30th, 2009, 11:06 AM
  3. Non-GM 4th Gen TCM calibrations
    By Cougar281 in forum Allison 5 & 6 Speed
    Last Post: March 17th, 2009, 08:17 PM
  4. OS Calibrations
    By Spindoctor in forum General (Diesel)
    Last Post: May 7th, 2008, 11:11 AM
  5. 85mm MAF calibrations
    By Chris81 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 27th, 2005, 07:19 AM
