Results 1 to 2 of 2
Thread: Older Laptop
    Default Older Laptop
    I have an older laptop with only the 9 pin serial port and no USB port, can I use some sort of adaptor to use EFILive? If so which do you recommend?
    The USB connector supplies power to the FlashScan interface, the serial port does not supply power. No RS232->USB connector/convertor will do that - unless it is powered from a seperate power source.
    I have not used a PCMCIA to USB convertor, but I believe they exist and would probably work with EFILive.
    Lastly, the minimum specs for EFILive is Pentium 500MHz. If your laptop does not have a USB port it probably falls below the speed specification as well.
  1. older 4L60E with E38
    By v8vegaman in forum Gen IV V8 Specific
    Last Post: January 8th, 2010, 03:06 AM
  2. possible to unlock 6th & 7th gear on older allison?
    By rubbersidedown in forum Allison 5 & 6 Speed
    Last Post: March 18th, 2009, 04:16 PM
  3. Using Flashscan V2 with LS1 Engine Swapped to Older Chassis
    By Mikey 97Z M6 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 31st, 2009, 07:55 AM
  4. Older OBD2 V6 support?
    By Telco in forum General (Petrol, Gas, Ethanol)
    Last Post: April 30th, 2008, 02:49 AM
  5. Reading the older IL4 PCM's
    By GMPX in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: January 10th, 2008, 03:54 PM
