I have version 7.5.4 (build 44) and firmware version 2.5.15 (march 18, 2008) and bootblock 2.5.04. Is this software stable and safe for flashing a LMM ECM (os 12617103) ??
reason i ask is beacuse I have flashed my lbz nearly 500 times flawlessly, but last night I licensed and flashed a LMM and afterwords the oil pressure, engine coolant, and fuel gauges did not function, and the truck would not crank. I have seen failed body control modules or body control modules that get kicked off-line cause similar symtoms. Is there a way somehow with after flashing with EFI the bcm is dead or not on-line with the rest of the system??? glicth or something? i can still flash the ecm with no problem but cannot get any type of tuner or code reader to get any information out of it, as well as no crank condition. all fuses are good, battery condition is good.
has anyone had any similar issues on an LMM? solutions/resolutions/suggestions? unfortunatly the truck is at athe dealer (hes a friend of mine, and was going to do a few tests with a techII), as it seems aparent the problem is someware other than the ecm or tcm. I will see what and I didnt think that EFI can do anythign to the bcm.
Thanks in advance for the help guys.
