Results 1 to 4 of 4
Thread: key code
    Aug 2008
    Default key code
    Can someone help me so i can get started? I registered the software under the help tab (it doesn't say weather or not it needs an internet connection). Next I go to the register VIN with V2 under help tab. Says I have 2 available that came with software. So how do I get mine entered so I can get started. Cannot find anything in instructions. All data shows up on screen but at bottom it asks for Authorization code (key code supplied by efi live). Did this key code come with my package wrote down somewhere of do I have to contact efi live to get it? Software is loaded and i'm connected to the DLC but cannot read anything. I am anxious to get started and getting frustrated. Am I even doing this right or am I completely missing something?
    Jan 2005
    Welcome to the forum Beaukz28.
    You should have received a blue card with your EFILive purchase that contains your license information.
    To licesnse your PCM to Flashscan is done when you attempt to flash the PCM.
    Aug 2008
    do i need to be online to register it?
    Also, I want to read the stock PCM calibration so I can save it but that isn,t lit up in the drop down menu for me to select. It seems like I'm not comunicating with the vehicle. Not sure why. I will reread and try again. Thanks for your time.
    Quote Originally Posted by beaukz28 View Post
    No, you don't have to be onlein to register it... just go Help->Register and enter the details from the blue card.
    Have you been able to read the PCM...?
    V2 displays the protocol (CAN/VPW) and the module count in the lower right corner of the LCD screen... press CTRL+OK until you see the protocol and a non-zero module count... then using the tunetool software you should be able to read the flash... no license is required.
  1. Wtf authentication code????
    By LMMpioneer932 in forum FlashScan V2
    Last Post: April 13th, 2010, 11:16 AM
  2. egr code?
    By hutch in forum Duramax LLY
    Last Post: October 3rd, 2009, 04:55 AM
  3. Code P062F and Code P0633 Help
    By Airtime in forum General (Diesel)
    Last Post: September 28th, 2009, 01:57 AM
  4. code question
    By justin123 in forum Gen III V8 Specific
    Last Post: April 29th, 2009, 10:12 AM
  5. Code P0480
    By Chalky in forum Gen III V8 Specific
    Last Post: August 19th, 2007, 03:29 PM
