Results 1 to 3 of 3
Thread: EFI Live PID CMPRET reporting incorrectly
    Oct 2008
    Default EFI Live PID CMPRET reporting incorrectly
    0411 PCM. Got a constant code of P1345 (cam crank correlation error). PID for cmpret is reporting -45.xx degrees. Car starts and runs. Distriutor cant be out that much. Any ideas....
    Oct 2008
    Help.....EFI LIVE????
    Lifetime Member Aloicious's Avatar
    Nov 2007
    Quote Originally Posted by slow89irocz View Post
    it sure can, I had to pull and restab my dizzy last monday (long story) but after re-stabbing it, it would start and ran fairly well, the CMPRET was reading -24* or so, after adjusting I got it to +- 2* just fine. a VERY slight movement in the dizzy will make a fairly large adjustment on the CMPRET. 45* is a bit but you MAY also have the dizzy 1 tooth off, which would (I think) cause a larger CMPRET offset.
    just unloosen the dizzy bolt a little and adjust it, CCW to go positive CW to go negative, rev past 1k in between adjusting to re-calculate the CMPRET. if you can't get it in the +- 2* range I'd try re-stabbing it one tooth over to see if it's closer.
    edit- not sure what vehicle/engine you're checking, but mine is a '96 C1500 5.7L vortec L31 in the sig.
    1996 c1500 gen1e 5.7L - the "LS31", 24x CNP, LS2 coils, modified T56, 12200411PCM running COS3, zz4 cam, custom MPFI, etc. coming soon: Twin Turbos
  1. Crank Idle table is defined incorrectly in '06 GTO Auto
    By Johnyhotrod in forum Gen IV V8 Specific
    Last Post: November 23rd, 2014, 06:58 AM
  2. MAF over reporting by 4-5%
    By icetraxx in forum E37, E38 & E67 PFI ECM's
    Last Post: May 18th, 2010, 03:24 AM
  3. 98 pcm reporting "not ready" at emission testing.
    By ChucksZ06 in forum Gen III V8 Specific
    Last Post: May 7th, 2009, 01:52 PM
  4. Vortec 454 CMPRET?
    By N0DIH in forum Gen III V8 Specific
    Last Post: September 2nd, 2008, 08:27 AM
  5. n00b reporting...
    By lastcall190 in forum Lounge
    Last Post: October 21st, 2007, 02:00 PM
