Results 1 to 6 of 6
Thread: AFR is incorrect from FlashScan
    Jul 2007
    Default AFR is incorrect from FlashScan
    I use the FlashScan box routinely. This time when I start logging data I noticed numbers around 5.0 and in that range. As a cross check of the wideband, my analog meter is showing up correct as is the logworks.exe data.
    I also have a 3rd piece of software for logging the serial lc1 and its correct also.
    This happens where BBL or pass through. It also appears the font is smaller on the display now for the A/F.
    SO, is there a way to reset the FlashScan somehow? The serial data is wrong.
    Or is this one done for? I'm going to double check, but it also looked like the lambdas were correct, but a/f way off.
    07 Silverado DMax Classic
    02 Z06 LS3 416, 805rwhp, TFS245, Wiseco, Callies Crank/Rods, Iskendarian Lifters, Crower Rockers, FAST102/90, ATI Damper, 1-7/8 Kook's LT, QkTime Shield,Tolle-Fab 8pt
    Old Engine: 1/4mile = 9.6/146 New Engine:?
    EFI Live Tune/Scan v7.5.27, EFI Live Scan and Tune v8.2.23, build 276, BootBlock 2.07.06, FirmWare 2.07.52, 512K RoadRunner (12.14.R), Innovate Serial LC2x2
    COS5/12212156 For 2002 Z06 Manual Vette
    TFZ_Z06,
    Is this with the LC-1 analog AFR (brown wire)...?
    Which AFR and BEN pids are you logging...?
    Do you have a DMM/voltmeter...?
    Connect one AA battery to the V2 inputs, see what V2 says, compare with DMM.
    Joe
    Jul 2007
    TFZ_Z06,
    Joe
    Thanks for stepping in. I've noticed once or twice the LC1 has reset itself.
    I reprogrammed it for the right fuel and its back on track. Maybe I fumbled fingered the keyboard.
    Jan 2005
    I've had my LC-1's automagically reset once or twice before as well. The serial data follows the programming of the channel 1 output.
    Mine has done this several times also.
    Senior Member Hyper99's Avatar
    Oct 2005
    Same here - I'm on the third time - second unit.
    99 Silverado 2500 Extracab Longbed
    33" BFG's - American Racing Rims
    Custom Dual Upper console gauge mount w/Autometer Sport Comp - Pyro, Oil Temp
    Autometer Sport Comp Boost/Vac in Custom Hypersonic Gauge Mount in dash
    LS-1 6.0L w/AFR 205cc Street Heads
    Vortech V2 blower
    42# Injectors
    Comp Cam - Custom Street Grind
    TTS Catback Exhaust
    Innovate LC-1 Wideband O2
    Tune and Trans mods via EFILive V1-V2
  1. Just reloaded EfiLive and is now saying my ETC is incorrect
    By Koncrete in forum Gen III V8 Specific
    Last Post: April 3rd, 2009, 07:35 AM
  2. Cylinder Volume? incorrect?
    By yellowC6ohio in forum Gen IV V8 Specific
    Last Post: June 12th, 2008, 03:42 PM
  3. one or more incorrect segment checksums?
    By dbaxter_ss in forum General (Petrol, Gas, Ethanol)
    Last Post: April 20th, 2005, 03:33 AM
