Results 1 to 3 of 3
Thread: IAC steps??
    Jan 2007
    Default IAC steps??
    Burb seem to idle fine...although takes a second to find idle at times when starting.
    Can someone tell me if the IAC steps seen in this log look normal?
    I've been reading that I should be around 60? I see mine are closer to 20 when around 75+oC???
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Oct 2004
    It is never getting to 0 in the log so there is still room for the IAC motor to step out further. I'd probably aim to have them around 40 though at full warm idle.
    Andrew
    EFILive Crew
    Jan 2007
    Thanks Andrew.
    Howard
    DUCT TAPE.
  1. Data Log steps
    By meshoooo in forum General (Petrol, Gas, Ethanol)
    Last Post: October 25th, 2008, 07:05 AM
  2. IAC Steps and near stalling....
    By LS1_Dragster in forum Gen III V8 Specific
    Last Post: June 10th, 2008, 01:06 PM
  3. how bad is 140 IAC steps?
    By gcross in forum Gen III V8 Specific
    Last Post: January 29th, 2007, 07:15 AM
  4. IAC steps.
    By Big Kahuna in forum General (Petrol, Gas, Ethanol)
    Last Post: January 9th, 2007, 11:16 AM
  5. IAC vs IAC EA vs steps
    Last Post: March 23rd, 2006, 04:54 PM
