How many degrees is ok, vs not ok?
I can't get below -7.5 degrees, the dist cap is physically hitting the intake.
No fault, PCM is yelling at me about it. If no fault is the PCM compensating ok and I don't need to worry about it?
Or do I need to pull dist and move a tooth? I am not aware of the dist being removed ever.
