Can anyone fill me in on what to do with the IFR table if I am using a regulator that is from Aeromotive with a vacume port hooked up to manifold vacume source.
With a return style system and vacuum referenced FPR you should be able to just fill in the same number all down the IFR table.
Thanks a bunch Thunder. Makes sense now that someone else mentions it.
