Results 1 to 10 of 16
Thread: VE Smoothing
    Default VE Smoothing
    Hey guys.. my VE Table looks like the Rocky Mountians..
    How do you guys smooth it?
    Im workin on it but it takes forever to get the spikes out and stuff.. Next i have to Flash this tune in and go check the AFR..
    Just lookin for some advice...
    Thanks guys!
    If it doesn't look smooth don't panic. When using the BEN's sometimes the engine requires little spikes, you will find you hit smooth and then the AFR's go out of whack. Believe the wideband, don't be overly concerned about how the VE table 'looks' (unless it is really messy).
    Post a pic of it.
    Jan 2007
    I paste my BEN's in an interpolation spreadsheet, then I copy the adjusted BENs from the spreadsheet and paste them into the tool... It really helped with the rocky mountain affect I had going on in my tune...
    i tried using the interpolation spread sheet awhile back and it threw it all out of wack
    Reason i askin this is cause my spark is goin crazy when i get in boost..
    Lemme try to get a screen shot real quick.
    Oct 2006
    Looks like a problem with transient filtering to me.
    What is your filter set?
    The Tremor at AIR
    Quote Originally Posted by 5.7ute View Post
    Where is this Filter?
    Oct 2006
    In the scan tool next to the map configuration buttons(A,B,C etc)
    You build a filter to remove transients & apply to the log file before copying & pasting to your tune file. There is a basic filter set in the autoVE tutorial that is a good starting point. Have a search for filters & you will find some more complete sets on this forum.
    The Tremor at AIR
    OHHH.. i knew that.. Gah.. I was tryin to think of something in the tune that had to do with Filters..
    I have everything from the Tutorial done in my Scan tool. but i did forget to apply them. So thats my first mistake.
    When i get home i need to do a FAC and start over with my AutoVE...
    Thanks for the help man!
  1. Why should we use the smoothing after tuning VE ?
    By wesam in forum Gen III V8 Specific
    Last Post: May 25th, 2010, 03:33 PM
  2. smoothing spark table
    By smslyguy in forum Gen III V8 Specific
    Last Post: April 12th, 2010, 12:38 PM
  3. Smoothing Maps
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: March 10th, 2008, 05:44 PM
  4. Smoothing in the VE table??
    By oztracktuning in forum General (Petrol, Gas, Ethanol)
    Last Post: March 12th, 2006, 06:31 AM
  5. What are your smoothing techniques
    By Dirk Diggler in forum General (Petrol, Gas, Ethanol)
    Last Post: June 23rd, 2005, 12:08 PM
