Page 12 of 12 FirstFirst ... 2101112
Results 111 to 117 of 117
Thread: E38 VVE Setup Guide
  1. #111
    May 2015
    Try it, but note that the VVE surface should "flow" and not have any abnormal/sudden change.
    Yep there isn't any crazy steps in it, if it's not my VVE then where should I be looking to get my idle AFR back closer to the commanded? Or is it a case of leaving it since it idles happily at these numbers.
  2. #112
    May 2015
    I'm not sure what I'm doing wrong but I cant seem to get this VVE process working. it either causes huge peaks in areas and huge dips in others unless I use the copy and fill process, but when I use that it seems to change my logged data to much and don't get the desired effect in AFR? I have tried to attached a log but it wont so here is the latest tune file after applying this BEN Map.
    Clayton Mafless13.ctz
  3. #113
    May 2015
    Found my problem, if you set map precision to 3 any numbers over 1 become .025 ect if it's set to 2 the number shows 1.02. So every time I would paste and multiply it would cause issues. In the mean time any rich spots have been sorted but all the lean spots never changed as they would multiply by .025 cause a huge hole then get smoothed out once I would gem coefficient and vve
  4. #114
    Apr 2007
    Would this tutorial apply to a 2015 Camaro SS with E38 ?
  5. #115
    Quote Originally Posted by Mrbowtie26 View Post
    Yes, all E38/E67 and the general concepts apply to the E78/E39/E39A/E92 with some minor tweaks.
  6. #116
    E92 requires a calc pid for MAP:BARO ratio (which is used to reference the axis of the VVE tables)...
    i.e. define CALC.MAP_BARO to be {SAE.MAP.kPa}/{SAE.BARO.kPa}.
  7. #117
    Bump again.
    Links for easy reference:
    E38 VVE Setup Guide
    Virtual VE Tutorial
  1. E38 / E67 VATS disable guide
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: September 20th, 2019, 10:08 AM
  2. Tuning Beginners Guide
    By NASABlue in forum Gen III V8 Specific
    Last Post: September 30th, 2009, 02:37 AM
  3. Beginners guide to tuning
    By ringram in forum Tutorials
    Last Post: June 17th, 2006, 10:46 PM
  4. Draft LC-1 Guide
    By 98WS6_JPM in forum General
    Last Post: May 12th, 2006, 02:53 AM
  5. PCM tuning guide
    By 2000ssnb in forum General (Petrol, Gas, Ethanol)
    Last Post: September 3rd, 2004, 05:42 AM
