Results 1 to 10 of 10
Thread: How do i setup my PIDs to log?
    Dec 2007
    Default How do i setup my PIDs to log?
    I have autometer 2246 transducers, wiring harnesses and plugs. ill be using these to monitor drive pressure boost and boost pressure. what are the steps i need to take to logs these and log them in psi?
    Is the output range of your transducers 0V to 5V...?
    Can you provide some psi/kPa sample points for various voltages in this range...?
    0V == what psi
    5V == what psi
    Is the output linear wrt pressure...?
    You provide 5V power/ground to power the transducer (I assume);
    you connect the transducer output/ground to the FlashScan input/ground;
    From the voltage/psi relation, we can make a calculated pid for this.
    Depending on you car year/model, if you delete the EGR you can use the EGR circuit and the EGR voltage pid.
    Do you have FlashScan V1 (LEDs only) or FlashScan V2 (LCD and LEDS)...?
    Dec 2007
    ok i have them showing up in the pids i now need a PRN number for my second input.
    i have both a v1 and a v2 ill be most likely using the v1 on my truck
    the voltage on it is like what others had in other posts i think its .5-4.5
    i have attached my calc_pids file for you all to see what else i need to do
    also when the PIDs show up they say they are invalid, however i do not have them hooked up yet. does that make a difference?
    Jan 2005
    When a PID shows as invalid, right click it and select "more info..." The resulting dialog will tell you whats missing.
    Dec 2007
    this is what i see
    Boost Pressu {CALC.BP}
    Expression:
    PSI = ({EXT.AD2}*25)-12.5
    is NOT valid because:
    Required parameter {EXT.AD2}, at position 11 is not selected.
    PID value cannot be determined because
    the following error would occur:
    Expression not valid: Required parameter {EXT.AD2}, at position 11 is not selected.
    Dec 2007
    this is the other one
    Drive Pressure {CALC.DP}
    Expression:
    PSI = ({EXT.AD1}*25)-12.5
    Required parameter {EXT.AD1}, at position 11 is not selected.
    Expression not valid: Required parameter {EXT.AD1}, at position 11 is not selected.
    Dec 2007
    this is my calc pids file
    # File details
    # This section defines various details about the file format.
    *FILE
    #Parameter Value Description
    VERSION 7.1.1 File version
    DECSEP . Decimal separator used in this file
    # Units
    # See sae_generic.txt for more information on the *UNITS section
    *UNITS
    #Code System Abbr Description
    PSI Imperial PSI "Pounds Per Square Inch"
    # Add slot definitions here
    # See sae_generic.txt for more information on "SLOT" formats
    #Units Low High Fmt Expression
    *CLC-00-001
    PSI 0.00 100.00 .2 "({EXT.AD1}*25)-12.5"
    *CLC-00-002
    PSI 0.00 100.00 .2 "({EXT.AD2}*25)-12.5"
    *PRN - Parameter Reference Numbers
    # See sae_generic.txt for more information on the *PRN section
    #Code PRN SLOT Units System Description
    CALC.DP F006 CLC-00-001 PSI Fuel "Drive Pressure"
    CALC.BP F006 CLC-00-002 PSI Fuel "Boost Pressure"
    In the scantool, under the PIDs tab, select EXT.AD1 and EXT.AD2.
    Dec 2007
    what about a PRN number for my second sensor how do i figure out what i can use? can i just got with F007 or is the something somewhere that i get this number from
    Yes, change the second F006 to F007.
    (I usually make the Fxxx number the same as the xxx in CLC-00-xxx).
    And change PSI to lowercase psi (in 4 places).
  1. RR Setup
    By Harrismarine in forum RoadRunner Real-Time PCM Emulator
    Last Post: May 12th, 2009, 03:25 AM
  2. LC1 setup for e85 ?
    By yellowC6ohio in forum General (Petrol, Gas, Ethanol)
    Last Post: June 13th, 2008, 04:11 AM
  3. Pic of my setup.
    Last Post: September 13th, 2005, 09:45 AM
  4. What is the best way to setup PE VS RPM?
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: August 2nd, 2005, 03:33 PM
  5. 2 bar map setup
    By AGRO in forum General (Petrol, Gas, Ethanol)
    Last Post: June 12th, 2005, 04:39 PM
