Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 40
Thread: CASE Learn on a RR?
  1. #11
    Lifetime Member N0DIH's Avatar
    Jan 2006
    So what issues show up that if CASE Learn isn't done that could hurt tuning, engine, etc?
    Is there anyway that that memory area can be read from the old PCM and manually written into the RR? If the RR is a true ROM Emulator, it should have all the addresses available, I am betting that EFILive or TunerCatRT is writing to not all the addresses.
  2. #12
    Jan 2007
    Pretty sure you just won't be able to detect misfires if case relearn isn't done. I know alot of people never bother.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
  3. #13
    Jan 2006
    AJ mentioned that he thinks the fuel trim learn is disabled when CASE Learn is not learned. My engine never shows the learn PID as yes, it is always No.
    If that is all, I don't really care....
  4. #14
    Member tazinhawaii's Avatar
    Apr 2006
    I spent many months troubleshooting not being able to CASE learn. First, I run continuously with the Roadrunner (stock PCM has been collecting dust on the shelf), and the CASE relearn works perfectly with mine. The only oddball thing is that when I disconnect the battery for more than a few minutes, I have to re-perform the relearn. As for running without the relearn done. When I haven't done the learn, my car runs like crap. Bucking, sputtering, etc. As soon as the relearn is done, no problems. So there is something to doing the learn besides misfire detection.
    Derrick
    1969 Camaro, LS3, 4L80E, Dana 60 rear, Air Ride, 19 and 20" wheels, Baer Brakes, and a lot more.
    2008 Charger SRT-8 Super Bee, Exhaust and Cold Air kit (Wife's car)
    2007 Yukon XL Denali, Family Hauler
    http://s330.photobucket.com/albums/l...i/69%20Camaro/
  5. #15
    Aug 2008
    i know this is an old thread but there is no guilt that i hijacked it.
    glad i found this thread, taz saved the day. i have been beating my brains out
    on a poor running car (sometimes) with the same symtoms.
    the car:
    '02 Z heads\cam put the roadrunner in it in sept. for the cruise to memphis for the
    LSx shootout. tweaked it there and back with some positive changes.
    ses light came on P1336 tried to do a relearn with an OTc gynensis and i could not.
    the car ran great so after getting tired of the light i set it to report no error and forgot about it. slowly it seemed to run like crap. starting with a cold surge and an intermitent
    lock up tcc.
    it got to the point of what taz described overnight. it was missing though the misfire
    monitor did not show it. car ran like crap unless you hit PE then it ran like a raped ape.
    i set P1336 to an A code and it was ok code wise but the car ran poorly.
    i put the 411 back in and it was problem solved.
    i have had a check sum error for 2 years or so no matter what i am using it in. it never seemed to care. this has been the longest i have had it in one car.
    i am thinking a complete format is in order. anyone know how?
  6. #16
    Jul 2003
    I guess you guys are seeing an issue with the PCM itself. I never had an issue with the roadrunner like this. Although my latest issue was that the car didn't want to fire up. So might be worth noting this.
  7. #17
    The CASE learn routines in the PCM require that it writes the learn values to the flash memory so they aren't lost if battery power is removed. Of course there is no flash memory in the Road Runner so it can't be learned.
  8. #18
    Jul 2003
    I don't see why it doesn't work. All it has to do is write to the emulated portion... I haven't tried it, but... I think it stores LTrim data IIRC...
  9. #19
    Jan 2006
    Ross, if one were to take off the flash, or to read the RR, can you find those memory locations and read them, so the CASE learn can be transferred from PCM to PCM so for people like me who use the same RR in multiple PCM's/vehicles, that I can keep my CASE learn handy?
    Thanks!
  10. #20
    Quote Originally Posted by Highlander View Post
    Because the RoadRunner has no flash memory! The PCM code is designed to write the values to flash memory, not RAM, there is a big difference.
    Quote Originally Posted by N0DIH View Post
    Thanks!
    Again, it's not stored in the RR, ever.
    On a normal LS1 PCM EFILive gives you the option to retain the CASE data on a full flash to save the relearn procedure needing to be done.
    In your situation, when you are finished tuning with the Road Runner and you refit the original PCM there should be no problem with the CASE data as the original PCM will still have it stored in flash.
  1. CASE Learn not working?
    By DPS in forum General
    Last Post: June 11th, 2010, 05:49 AM
  2. Where is CASE learn stored?
    By N0DIH in forum RoadRunner Real-Time PCM Emulator
    Last Post: October 17th, 2009, 05:06 AM
  3. EFILive v.7.5.5.xx Cannot CASE Learn
    By Denaliano in forum Gen III V8 Specific
    Last Post: April 18th, 2009, 08:28 AM
  4. Where to LEARN
    By board350 in forum General (Diesel)
    Last Post: April 26th, 2008, 09:22 AM
  5. CKP learn
    By ds8 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 16th, 2006, 04:02 PM
