DTC Query P0852
Cannot find any info on this code, can someone shed some light please.
TIA Boyley
Joe (Moderator)
P0852 Park/Neutral Switch Input Circuit High
08 Holden Calais L98 A6 AUto mate, thanks
I saw something about park/neutral fault??
Joe (Moderator)
I'm not sure exactly what the description means, other than the P/N switch or its wiring is open circuited (pulled high internally) or shorted to voltage (pulled high externally).
I had the cars front end off when doing the cam so may have inadvertantly disconnected something then.
Cleared the code and hasnt come back so not ot worry, thanks anyhow
2014 Corvette Convertible, Torch Red, A6, Z51, 3LT, NPP Exhaust
Originally Posted by
eboggs_jkvl
Yes thanks Elmer
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
