Results 1 to 6 of 6
Thread: misfires... after cam
    Lifetime Member ZL1Killa's Avatar
    May 2005
    Default misfires... after cam
    Quote Originally Posted by jimmyblue View Post
    If it was one or two plug wires that would show up as a
    specific cylinder misfire code. More likely is that the cam has
    just made the motor "trip the threshold" for declaring a misfire
    (as opposed to actual misfiring). More crank ripple does this,
    see it with lightweight torque converters too. If it stays just
    "random" then I'd start upping the threshold values in the
    misfire tables (x2 everything for starters).
    http://www.ls1tech.com/forums/showthread.php?t=983021
    Where are these tables that he is talking about in EFI LIVE, lol. it has been a while since I changed my cars tune and messed with it so i'm a little rusty. gettin back on that learning curve
    01 T/A WS6 #4984 STOCK 342HP and 352TQ [/b]MODS:Too many to list, PM...funny rear mount.. father/son build.
    [Quote :ur car is sneezing!!!!]
    I KNOW KUNG FU.
    My STS build: http://www.ls1tech.com/forums/showthread.php?t=631954
    453HP 475TQ @6psi
    .....CAM'd, IC'd, and 7psi'd #'s coming.....
    May 2005
    ok found them. which ones do I change to a higher value? all of them?
    I KNOW KUNG FU.
    453HP 475TQ @6psi
    May 2005
    guys, any input. Not trying to be demanding but figuring that after cam swaps and such that people would know this as an easy one
    I KNOW KUNG FU.
    453HP 475TQ @6psi
    Feb 2008
    '04 ecsb Chevy: 4.8L turbo ,EFILive tuned
    May 2005
    well... maybe. thanks for that post/link too. didn't get a chance to log misfires, but I did mess with the misfire tables. I'm not getting knock/detonation, so I don't think it applies to me
    I KNOW KUNG FU.
    453HP 475TQ @6psi
    May 2005
    ok, had to modify the misfire thresholds table(s) in the tune and it went away, car runs great. for some reason 220 or low 22x cams like to come right within the factories computer misfire threshold and trigger it.
    problem solved and she runs great
    I KNOW KUNG FU.
    453HP 475TQ @6psi
  1. CASE & Misfires
    By Cougar281 in forum Gen III V8 Specific
    Last Post: May 24th, 2010, 04:21 PM
  2. Corvette C5 Vortech misfires
    By Hocky in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 25th, 2009, 01:18 PM
  3. How do you log misfires in COS5?
    By onfire in forum Custom Operating Systems
    Last Post: August 17th, 2009, 09:15 AM
  4. Misfires until warmed up......
    By ViolatorTA in forum General (Petrol, Gas, Ethanol)
    Last Post: July 15th, 2006, 10:34 PM
  5. V7 software issue scanning misfires
    By BigTex in forum General
    Last Post: March 14th, 2005, 10:29 AM
