Results 1 to 10 of 10
Thread: Serial wideband.....CAN or RS232?
    Default Serial wideband.....CAN or RS232?
    Can someone confirm if the serial output is either CAN or RS232? I am looking at purchasing an expensive WB and want to make sure it puts out the correct serial data.
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Jul 2007
    Quote Originally Posted by Redline Motorsports View Post
    Howard
    The RJ connector is an input for SERIAL data. You should be able to wire up a wideband device that is serial with +/- and transmit line. Using custom
    calcs, you should be able to configure it.
    07 Silverado DMax Classic
    02 Z06 LS3 416, 805rwhp, TFS245, Wiseco, Callies Crank/Rods, Iskendarian Lifters, Crower Rockers, FAST102/90, ATI Damper, 1-7/8 Kook's LT, QkTime Shield,Tolle-Fab 8pt
    Old Engine: 1/4mile = 9.6/146 New Engine:?
    EFI Live Tune/Scan v7.5.27, EFI Live Scan and Tune v8.2.23, build 276, BootBlock 2.07.06, FirmWare 2.07.52, 512K RoadRunner (12.14.R), Innovate Serial LC2x2
    COS5/12212156 For 2002 Z06 Manual Vette
    I meant input not output......thanks....
    The following is a air fuel meter I am looking to buy and BELIEVE it should work. Not sure about the outputs in serial are what V2 reads.
    This is the unit; http://www.ecm-co.com/afr1200.asp
    What is involved in calibrating the V2 to use another brand of wideband not listed in the current data base?
    Howard
    1-954-703-5560
    Howard,
    Is this what you mean: the LC-1 serial out and the V2 serial port are RS-232.
    Joe,
    To be honest, I got no idea on what I am trying to confirm! I simply asked the guys who make this wideband if it will put OUT a serial signal. They then asked if I was looking for CAN or RS232. I think it does both so theoretically this unit should work.
    If I did proceed with this unit, what is involved with setting up a new pid for the new output? I assume that even though its serial that its still a 0-5 volt signal........just cleaner?
    Howard
    1-954-703-5560
    Jan 2005
    There is a bit more to it than 0-5 vdc. CAN and RS232 are digital communication protocols that are not 1 in the same. I don't have access to my gear to dig around, but it might require a firmware update to support communication to that WB - I'm not sure how the guys are implementing protocol detection.
    Jul 2007
    Howard
    The input RJ connector on North side of device is where the FlashScan receives serial data. The EFI Live guys WILL be required to program the flashscan firmware so that it recognizes the packets, format thrown at it by the new wideband device. Otherwise, it will fail.
    I have personally written software that utilizes the LC1 and LM1 data packets so I have a pretty good idea of this.
    Your new wideband did state bidirection RS232, so thats good news. At worse case, you could wire in analog outputs and write calc pids to cover you short term while the EFI LIVE guys update the firmware.
    The other question is whether or not the new wideband mfg is willing to release the protocol to the public. It would only make sense, but if they have their own software, beware.
    Howard,
    Show them this post: http://forum.efilive.com/showthread.php?t=8115
    and explain that the LC-1 and LM-1 output the AFR in serial stream form using the protocol shown in the attached PDF...
    Then explain that FlashScan V2 has been programmed to recognize the serial AFR streams for various different widebands...
    They would have to communicate with Paul so that they and he can agree on a format.
    Most likely, they already have such a protocol/format implemented, but show them the above anyway, that way they will be clear.
    Joe
    Jul 2007
    Howard,
    Joe
    I guess you know that protocol wont' work w/LC1. The subpacket size is only 4 bytes vs 14 for the LM1.
    Quote Originally Posted by TFZ_Z06 View Post
    Yes, the title in the pdf says "LM-1 Serial Logger Specification #1"... is that what you mean...?
  1. Wideband serial update
    By Blacky in forum FlashScan V2 BB Logging
    Last Post: September 9th, 2010, 10:13 AM
  2. Serial Wideband AFR & B3601
    By WeathermanShawn in forum General (Petrol, Gas, Ethanol)
    Last Post: April 25th, 2010, 05:51 AM
  3. log serial wideband
    By b18cls1 in forum Black Box Logging
    Last Post: February 12th, 2010, 04:46 AM
  4. Can't log serial wideband anymore
    By white01ss in forum Tutorials
    Last Post: October 28th, 2009, 09:39 AM
  5. serial wideband
    By articSS in forum Black Box Logging
    Last Post: December 19th, 2008, 07:04 AM
