Results 1 to 5 of 5
Thread: Using the pcm controlled shift light
    Aug 2005
    Default Using the pcm controlled shift light
    Ok, i'm not the greatest with electrical stuff, could someone help me with instructions on how to setup a shift light in my 2002 Z06?
    I found a couple of threads on this, but i'm a little confused on what exactly to do as far as the wiring using the pcm pins and building a light (i'd like to do my own LEDs)
    Any help would be greatly appreciated.
    1992 Turbo LSX Notchback Mustang 275 radial car - under construction
    2008 Sierra 2500HD Duramax
    LED's don't work too well, you need to use real globes. The LED's will stay lit (dim) when not on.
    If using a globe one side needs to go to +12V Ign, the other side to the PCM pin, but sorry, I don't recall the pin number.
    FYI, on the Holden HSV they had a shift light from factory, they always false triggered, it's not the best system to use for a real shift light.
    Lifetime Member Garry's Avatar
    Jun 2006
    LEDs are pretty much fine - I've got some (6) ultra-bright yellow LEDs ... I hooked them up for starters to see how "bad" the glow during off-time is ... it's not too bad ... anyway, if it's too much for you, you can always add a bit of electronics to control the light with a transistor ...
    Anyway, I got mine in the air duct of the center console ... nice and mostly invisible ... if I don't want to see it at night, I can just close the vents
    Oh, and I've not had any problems with "wrong" triggering - they've not come on too early or outside the shift range, and according to my quartermile logs, it came on at the right time
    Garry Glendown * '17 Fifty 2SS MT * 99 Firehawk Convertible (for sale)
    Nice one, I just remember riding in Paul's (ex) HSV GTS which had a shiftlight fitted from factory, it used to come on (with an annoying beep) when taking off from a stand still every now and then
    My GTO has the shift light built in, but disabled from GM. Any idea how to enable it?
    2004 GTO M6
    - Custom tune
    -- KnN CAI
    --- IAT relocate
    ---- JBA catless mids
    ----- JBA catback
    ----- DBA 4000XS rotors
    ------ 05/06 rear bumper conversaion
    ------- 25% tint all arround
  1. Shift Light in 2k F-Body?
    By Garry in forum Tips and tricks
    Last Post: May 11th, 2013, 05:20 PM
  2. Shift Light
    By BRD-PREY in forum General (Petrol, Gas, Ethanol)
    Last Post: January 13th, 2009, 10:16 AM
  3. 04 GTO Shift Light
    By jpalamar in forum Gen III V8 Specific
    Last Post: December 5th, 2008, 03:04 AM
  4. Shift light?
    By traumadog in forum Gen III V8 Specific
    Last Post: December 4th, 2008, 07:10 AM
  5. shift light
    By RUTAN TA in forum General (Petrol, Gas, Ethanol)
    Last Post: July 17th, 2006, 06:07 AM
