Results 1 to 10 of 14
Thread: Weird VIN
    Sep 2007
    Default Weird VIN
    I read the 01 LB7 we bought tonight, and got a weird VIN number. ????i?B??C???0?&J is what is in the VIN box, I read it twice to make sure, and had the same results twice. I went on a test drive and logged it, I received the same vin message with the scan tool connected to the ECM. Any ideas?? My next day off, I am going to go to the dealer and make sure that the ECM has the latest OS from GM. 15188873 is the OS.
    Riley
    01 CCSB Chevy 4WD HD LB7, built trans, and some other stuff
    Can you send the *.tun file to me at paul@efilive.com?
    Sep 2007
    No problem it is on its way Paul
    Jul 2007
    Isn't that an indicator of a fried ecm?
    could a programmer have corrupt the ecm and erased the vin, I saw an 02 forget it's vin with a battery that crapped out and drained them both, dead truck had sat a while before it was relized
    04 LB7
    2010 LMM
    2015 LML
    Evidently, GM's TIS programmer will do that when things go wrong during a TIS reflash.
    Once that section is damaged, the Duramax software has a hard time fixing it.
    It may be difficult for EFILive to license the ECM once the VIN and serial numbers have been corrupted.
    Ross, (aka GMPX) says it is best to remove the chip and reprogram it to clean up that type of mess.
    If you can license the ECM when you try to flash it then just run with it. It will save you some messing around trying to get the VIN fixed.
    Unfortunately once that area of the ECM has been corrupted (TIS is known for doing it), there is no easy fix. You are actually lucky you can still read the ECM, normally when they are in this state they appear as being locked.
    Sep 2007
    Well I finally got back to the dealer, and reflashed the truck with no problems. I am curious if the ECM had been replaced, and not flashed when installed? I didn't think that was possible but who knows. Any ways all is good now.
    Sep 2007
    I lied, as I try to reflash the ecm, I get a message that says the ecm's serial number is missing, and that a full reflash is needed. How do I accomplish that? I have tried several times to reflash it, and get the same message. I cant even get to the message to lisence the ecm. help please. here is the new file that I read after reflashing with TIS 2000.
    Thanks,
    Riley
    A full flash is done by pressing the reflash icon next to the normal calibration reflash icon.
    FYI, the serial number of that ECM has been wiped clean by TIS.
  1. Weird fan problem
    By johnsZ06 in forum E37, E38 & E67 PFI ECM's
    Last Post: December 25th, 2008, 02:20 PM
  2. Weird AFR at idle
    By 5.7ute in forum Custom Operating Systems
    Last Post: December 7th, 2006, 12:04 PM
  3. Weird bug
    Last Post: September 27th, 2006, 09:42 AM
