Can anyone give me a quick description of what is required to convert a VX commodore to a L98 engine using the LS1 PCM?
I know that a few jumper wires need to be made for the injectors and cam sensor and I will also need a manual throttle body.
Is there also a deference in the crank sensor wheel? If so can they be swapped easily? Or is it a new crank.
Any help would be much appreciated
