can i change the rev limiter on individual tunes, or is it all done off of the base tune or number 1 tune??
right now i have the rpm limiter set at 4200 rpms and i am only hiting 3500
it only uses main tune rev limiter
you need to play with the throttle base injectiopn tables for individual rev limits. also make sure you max fule injected table extends to 4200 rom if you want to spin that.
Might want to look in the TCM, I believe that there is some RPM limiting in there too.
