Results 1 to 9 of 9
Thread: I Locked PCM but now have new V2
    Jan 2006
    Default I Locked PCM but now have new V2
    I locked a PCM on one of my own cars a while back just playing with the lock feature. I let efi generate a lock code, I could lock and unlock it fine. Fast forward to now and I try to unlock it and efi wont unlock it. Then it hits me, I had the orginal V2 box I had go out and I have a differnt one now. Is that why I cant unlock it? When I plugged into the car it acted as if I never plugged into it before. I still have the same laptop, and same streams in the V2 its just a differnt V2. Can I unlock it? Is the unlock code on my laptop somewhere? I really need into the pcm tochange some things ASAP.
    Nov 2006
    i think when you lock the PCM,
    it is locked to the cable itself. (V1/V2)
    Jan 2006
    Yeah thats what I always thought. Now Im kinda stuck, Im trying to unlock my own car so I can go to the track tomorrow.
    Lifetime Member JezzaB's Avatar
    Nov 2006
    Depending on how long ago and which version of the software you are running , im sure it now backs up all of the locks and licenses on the PC so that you can send one back to get repaired under warranty and apply them to the new one.
    This may help with what you need. I dunno
    Jez
    Jan 2006
    Any one from EFI know?
    Locate the file \Program Files\EFILive\V7.5\PCMLocks.ini
    Open the file with Notepad and find the section that matches the PCM's serial number that you want to unlock. Send the seed and key values to me at paul@efilive.com and I will send you back the unlock code.
    You need to find the file PCMLocks.ini (In the folder - \Program Files\EFILive\V7.5\Configuration), in that is the serial number and encrypted unlock code for every controller you lock. Take note of the serial number of the ECM you are trying to unlock (you can see that by using the 'Show PCM info' function in the tune tool) Flash > Show PCM Info
    Locate the serial number in the locks.ini file and send the info to either Paul or myself and we can give you the unlock code.
    You will need to look for something like this in the ini file -
    [2148CT053VK1]
    Seed=$2590
    Key=$4A0E56A0
    Where:
    [2148CT053VK1] = The PCM Serial Number
    Seed=$2590 = The Seed of the PCM
    Key=$4A0E56A0 = The encrypted Unlock code
    Edit: You beat me to it Paul!
    Jan 2006
    Thanks a million, I will get the info sent out tonight.
    Jan 2006
    Thanks Ross and Paul,
    I sent the info to Paul's email along with another file.
  1. locked ECM
    By duramaxdaddy29 in forum Duramax LB7
    Last Post: June 4th, 2008, 05:30 PM
  2. E40 ECM locked
    By LBZ_YFZ in forum Gen IV V8 Specific
    Last Post: April 4th, 2008, 01:37 PM
  3. Locked E40
    By Jakes4321 in forum Gen IV V8 Specific
    Last Post: March 22nd, 2008, 08:04 PM
  4. Locked PCM?
    By eboggs_jkvl in forum General (Petrol, Gas, Ethanol)
    Last Post: March 16th, 2006, 01:46 PM
  5. 98's (Locked)
    By 87gmc in forum General (Petrol, Gas, Ethanol)
    Last Post: August 3rd, 2005, 09:54 AM
