Results 1 to 10 of 15
Thread: Disabling Post injection on LBZ
    Lifetime Member LBZoom's Avatar
    Jun 2008
    Default Disabling Post injection on LBZ
    Hello everyone,
    I've read on this forum that you can disable the post injection cycle to increase fuel efficiency and that it is only in place for emissions purposes... I've messed around with it, but I was curious, should I be setting the table values to 0 or setting them to the minimum amount possible? I assume that if I set them to 0 it will disable it...same thing for disabling the EGR for a blocker plate right? Thanks guys!
    Nothing to worry about on the LBZ, the 'post' injection is only used with the LMM, did you mean pilot injection?, LBZ has that.
    Jan 2007
    gm told me the post inj event is used on the l bz
    and i also know when i dis abled it the egt did go down a little
    its only used for soot control on the lbz and dpf on the lmm
    this is from a duramax ecm calibrator (my cousin)
    08 gmc sierra6.0 4sp-e38/t42 k/n intake
    4x4 ext cab
    Jun 2008
    Okay, I guess I was a little confused because there is a table in my ecm for post injections 1 and 2...1 has no values entered in the table, 2 however has values entered in the table which made me think that they were in use. I'll take your word on it Ross because I know you're the man! Hypothetically though if it was in use, would entering a value of zero prevent the cycle from occuring?
    Don't take my word on that 100%!, I am basing it on the fact I've never seen a log file where the post appears to ever be active, more than happy to be shown otherwise.
    Jan 2007
    Quote Originally Posted by LBZoom View Post
    to answer the question-yes set them all to 0-will disable it
    also note the egt drop at part throttle driving
    4x4 ext cab
    Sep 2006
    Quote Originally Posted by dynarex View Post
    dynarex has proven this for us...I did it, you can do so at your own risk...
    2007 CC/SB 4WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SD Sleeves, SoCal Diesel
    2002 CC/DRW 2WD, McRat EFI Live, Trans, Trans Cooler and C3 clutch oiling mod by Mike L., SoCal Diesel
    Mar 2007
    I can confirm dynarex's findings as I have done this as well.
    Junior Member Donovan's Avatar
    Sep 2007
    Quote Originally Posted by The Neens View Post
    What is the risk? I have been running like this for over a year with no problems.
    E35A/A40 + DSP5
    Sep 2006
    Quote Originally Posted by Donovan View Post
    I haven't had any problems either...Anytime we modify our vehicles, we're taking a risk, that's all I meant
  1. no pilots, no post injection
    By SGFastMax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 4th, 2012, 06:55 PM
  2. Post Injection
    By petestoy in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 2nd, 2011, 12:31 AM
  3. Disabling post CAT oxygen sensor DTC? Possible?
    By andyfanshawe in forum Vortec V6/V8 Specific
    Last Post: April 29th, 2008, 03:33 AM
  4. Eliminating post injection
    By lucky1 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 10th, 2007, 12:08 PM
  5. C6 A/C not Disabling Under WOT
    By 5 Liter Eater in forum Gen IV V8 Specific
    Last Post: December 8th, 2007, 05:07 AM
