Results 1 to 5 of 5
Thread: HELP PLEASE!!! Error programming Vortec V6 4.3
    Aug 2008
    Default HELP PLEASE!!! Error programming Vortec V6 4.3
    Everything goes smoothly until the the Flashscan V2 tries to initialize bootlogger(or something) and an error comes up saying there was no response from the ECM. The Flashscan advises to uncheck high speed programming but still won't do anything. Error keeps popping up....
    Aug 2008
    Initializing BootLoader....
    ERROR....
    BootLoader Rejected ....
    Reason: No Reply.....
    Data Transfer was interrupted, Try unchecking "Use High Speed"
    I've tried about 5 times and still get the same Error. Maybe my ecm is not supported?
    I pm'd tech support.
    Does it only fail on your 4.3L...?
    Are you able to read the ECM flash contents...?
    Make sure you are using the latest V7.5.4 build 66 and the latest V2.05.20 firmware, available from our web site downloads page here:
    http://www.efilive.com/download.aspx
    Download both V7.5 and V8.1 - and read these posts:
    http://forum.efilive.com/showthread.php?t=8425
    http://forum.efilive.com/showthread.php?t=8426
    If you are already using the latest software and firmware, can you please locate the file:
    \My Documents\EFILive\V7.5\Bug Reports\YYYYMMDD_HHMMSS_Upload.blx
    where:
    YYYYMMDD is the year, month and day
    and:
    HHMMSS is the hour, minute and second
    that you attempted to reflash the controller.
    Please send that file to me at paul@efilive.com and
    include a link to this message so that I can correlate
    your file with this message.
    Aug 2008
    It worked on the 15th try It read the ecm with no problems and I actually used the Flashscan V2 a couple of days earlier to flash a calibration into my 2008 Silverado w/6.0 ltr (ECM & TCM) with no problems whatsoever! The only way I could get it to work on my 4.3 Vortec V6 was using a bench harness... I'll look for the error's and send them to you...
  1. Programming the DIC
    By Whippled 496 in forum Tips and tricks
    Last Post: December 14th, 2012, 04:44 PM
  2. vortec v6 to vortec v8 swap
    By grezzmky in forum Vortec V6/V8 Specific
    Last Post: September 21st, 2009, 06:49 AM
  3. Need Help Re-Programming The BCM
    By cwksf in forum General
    Last Post: July 26th, 2009, 03:05 PM
  4. Programming Silver PCM from 2001 S-10 4.3L to handle 97 Vortec
    By onegonewild in forum Gen III V8 Specific
    Last Post: May 1st, 2008, 02:42 AM
