Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: has anyone played with shift timing?
    Jan 2008
    Default has anyone played with shift timing?
    Has anyone played with the B5100, 5104, 5108 etc "desired shift timing" tables?
    I have built an ECU tune that tows good & pulls like a !*%$&@ at WOT.
    Now I would like to tighten up the shift firmness & remove the slush box feeling.
    It looks like simply changing the -100 # to say -150 or-200 ??
    2008 LMM 6spd
    thanks guys
    Jan 2007
    Ive heard its only tuning the shift timing for the oncoming clutch and that it won't have that much of a diffrerence, but I don't see why you couldnt go a little.
    Jan 2008
    Judging from what EFI has for a description, it looks like these are the lengths of time that the solenoids take to apply/release the clutches in order to shift to/from the next gear.
    So..... yeah, it looks like we should be able to make adjustments to the values, the only negative could be a harsh shift.
    Jan 2007
    I don't know anything about transmissions but ive seen where people have made tcm tunes and adjusted the shift times by about 50-250ms. I tried adjusting mine in the 70+tps area by about 25-150ms and on I think the 2-3rd shift it does something wierd. So im going to change them back to stock for now.
    Jan 2008
    thanks, goood to know. I have asked the same question on another forum, I will let you know if I get a response.
    Jul 2007
    I adjusted mine. It seemed to make it feel better without being too harsh. I didn't adjust it too much. You can find my stock tune as well as my modified tune on www.dieseltowingresource.com
    Jan 2007
    Has anybody ever adjusted the TCC duty cycle past where it was stock? What if you made it 100% could you get a little more holding power out of it?
    What about disabeling the g-soleniod at a diffrerent rpm? Ive heard the g solenoid lowers the main pressure at low throttle so if you disabled it at a lower rpm it would build more pressure faster?
    Lifetime Member Cougar281's Avatar
    Jan 2006
    Quote Originally Posted by cmitchell17 View Post
    You don't want to put the TCC DC to 100%; You'll burn it out because it's not rated for that duty cycle.
    Jan 2007
    Ok thanks, can a soleniod never be at 100%? Is there any benifit to disable the G Soleniod at a lower rpm?
    Jan 2006
    Depends on the solenoid. The TCC one isn't rated for 100%; not sure what the others are. I THINK the G-Sol was put there to get an extra .00000001 MPG for the EPA; I don't think it hurts either way (enabled or disabled).
  1. Billet LT1 Timing Cover - Clears Double Row Timing Chain
    By S10Wildside in forum Conversions / Aftermarket Parts
    Last Post: November 17th, 2009, 01:15 AM
  2. my box will only shift 1st and 2nd
    By trickas in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: August 3rd, 2009, 01:46 PM
  3. Anyone played with Spark dwell times?
    By Tordne in forum General (Petrol, Gas, Ethanol)
    Last Post: February 23rd, 2009, 02:59 PM
  4. why 1>2 shift happens at higher rpm than 2>3 shift?
    By 350SS in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 13th, 2008, 11:54 AM
  5. Disable adaptive shift learning after Shift Kit Install
    By BlackGMC in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 24th, 2008, 05:49 AM
