hi everybody
im getting a v2 from oz track tuning just wondering whats an ideal wideband sensor to get that works easy with the v2
hi everybody
i suggest the LC-1.
it is affordable, reliable, easy to use, supported with both analog and serial connection to the V2 and has all the PIDs that you will need already installed.
LC-1 Seems like one of the most popular. I have AEM UEGO and I'm not very happy with it... The AEM gauge never seems to have the same reading as the analog output, and there is no way to recalibrate the gauge for the sensor.
So if I had to do it all again I would buy a LC-1 and a XD-16 gauge. Maybe if I get some extra $$$ I'll sell my AEM and get a LC-1.
Just my 2 cents.
EDIT: Come to find out that my AEM Gauge was messed up. I called tech support and sent it back and had a new one in 5 days. Works like a charm now.
-CoryF
Last edited by CoryF; October 9th, 2008 at 08:37 AM. Reason: AEM Fixed my broken gauge
I am for the LC1 . It was simple and easy to install.
Roy 98SSSSSS
Tech Edge 2J1
http://wbo2.com/2j/default.htm
If you will be using it on other non-supported vehicles I would recommend the LM2 or LM1 since it has a display. They also move from vehicle to vehicle easy.
Al
