Results 1 to 9 of 9
Thread: EFILIVE _TUNE.EXE HANGING...on startup
    Jul 2007
    Default EFILIVE _TUNE.EXE HANGING...on startup
    When I try and start the program, it hangs. Any ideas?
    I tried reinstall and it still hangs.
    What is the proper uninstall procedure? I deleted folders and manually deleted registry info, yet when I install I get the fix/repair option.
    Anyone else had this problem? If so, what was it?
    07 Silverado DMax Classic
    02 Z06 LS3 416, 805rwhp, TFS245, Wiseco, Callies Crank/Rods, Iskendarian Lifters, Crower Rockers, FAST102/90, ATI Damper, 1-7/8 Kook's LT, QkTime Shield,Tolle-Fab 8pt
    Old Engine: 1/4mile = 9.6/146 New Engine:?
    EFI Live Tune/Scan v7.5.27, EFI Live Scan and Tune v8.2.23, build 276, BootBlock 2.07.06, FirmWare 2.07.52, 512K RoadRunner (12.14.R), Innovate Serial LC2x2
    COS5/12212156 For 2002 Z06 Manual Vette
    Nov 2006
    EFILive has done that since i`ve been using it,
    does it "hang" more than 10 seconds?
    it maybe your PC needs some maintenance, more RAM, defrag.
    you can speed up start up of many programs by adding /prefetch:1 at the end of the shortcut.
    example:
    "C:\Program Files\EFILive\V7.5\EFILive_Scan.exe" /prefetch:1
    "C:\Program Files\EFILive\V7.5\EFILive_Tune.exe" /prefetch:1
    Jul 2007
    Got 2 gigs in my HP530 laptop and it works fine. Its my
    9 sec desktop thats having a problem. It has 4 gigs ram mem, sata 1tr drive,
    gigabyte motherboard and its flat out fast.
    The program is just hanging indefinitely. Lucky its not my laptop. WTF.
    I just restored it while I was out on a SD tuning run. Hopefully its back to normal.
    If the most recent tune file that you loaded was on a network drive that is no longer available (or the folder is not available for some other reason - i.e. logging on as a different user), then next time you start the tune tool it will "hang" while waiting for the network drive to come back on-line.
    To prevent EFILive attempting to load the most recently used file, delete the most recently used file list in the registry by removing all keys: \\HKEY_CURRENT_USER\Software\EFILive\V7.5\Properti es\Mru\BinFileNameX where X is all numbers from 0 to 7.
    The correct procedure for uninstalling EFILive is to uninstall it using the settings in the Control Panel->Add/Remove Programs.
    Then delete the registry key: \\HKEY_CURRENT_USER\Software\EFILive\V7.5
    Backup any files that you want to keep, then delete:
    \My Documents\EFILive\V7.5
    and
    Repeat for EFILive V8.1 if you have that installed.
    Jul 2007
    After I uninstall and reinstall the V7.5 folder never shows up in regedit. Ideas? I tried installing build 64 and the V7.5 folder reappears, so I go in and delete all the Bin FileNamexs, except for there are no file names associated with those registry values and run the program again. It hangs.
    Then I reinstall build 66, the V7.5 folders disappear in the registry.
    Any ideas? Also, this is not on a network.
    Jul 2007
    Blacky,
    Is there some kind of debug log or anything I can review as the program loads?
    I'm guessing you pull the last few opened tunes from the registry, then
    load the last one.
    Jul 2007
    I have quite a few cables next to my PC. I thought I had plugged up my USB cable from an external drive I have. With so many cables in the same place, I grabbed the wrong one. My luck, I plugged up theAUTOTAP cable.
    In any case, as soon as I removed the cable, EFI Live came to life again.
    I restored my harddrive and lost 10 days of email and other data trying to figure this one out.
    So can I assume it is working again?
    On the registry thing... The registry details are not added to the registry until the first time you exit the EFILive software.
    If you ever want to reset the software to "installation default" you need to exit from all EFILive software, delete the reg keys, rerun the software.
    If EFILive tries to load a setting from the registry and it is not found, it uses the install default setting. When you exit the software, EFILive saves ALL of its settings into the registry.
    Jul 2007
    Yes, its working now. Thanks for the registry info and support.
  1. Hanging idle
    By bobbycollier in forum General (Petrol, Gas, Ethanol)
    Last Post: April 13th, 2009, 04:24 AM
  2. Newb help w/ hanging idle & logging
    By LS1-450 in forum Gen III V8 Specific
    Last Post: April 19th, 2008, 11:15 PM
  3. Hanging idle on stock LS7
    By Stoichiometric in forum Gen IV V8 Specific
    Last Post: March 21st, 2008, 08:37 PM
  4. Low hanging fruit and other newbie questions.
    By NewV in forum Gen III V8 Specific
    Last Post: December 6th, 2006, 04:04 PM
  5. Startup Airflow and Startup Friction Airflow whats the difference
    By carneb in forum General (Petrol, Gas, Ethanol)
    Last Post: July 31st, 2006, 08:59 AM
