Results 1 to 5 of 5
Thread: GM GEAR pid unable to validate,
    Senior Member alian's Avatar
    Jun 2008
    Default GM GEAR pid unable to validate,
    Another silly question, I am having trouble validating gear pid when logging with the laptop. It wont support. I have it in my optifile and when BBLogging it works. What am I doing Wrong
    Ian,
    What year/model and what PCM/OS...?
    Jun 2008
    Ian,
    Hi Joe, Its a E38, OS 12607218,In a 06 Vz A4.
    Cheers Ian
    Quote Originally Posted by alian View Post
    BB Logging allows both trans and engine PIDs to be logged simultaneously.
    The V7 PC based logging only allows engine OR trans PIDs (not both) to be logged simultaneously. (The V8 software, not released yet), will allow both.)
    When using the V7 PC software, it may be that you are validating the gear PID when connected to the ECM and it may only be valid for the TCM.
    Jun 2008
    OK Thanks for that, So to validate the gear pid I need to connect to the TCM?. The only reason I was laptop logging is because I was monitoring SEMRET and I couldt get it to work when loaded into my optifile. I have fixed that problem now and am moving on so will be BBLogging again tomorrow. Thanks for that because I was waisting a lot of time going over and over trying to get it to work.
    Cheers Ian
  1. cant validate rafig pids
    By rpmauto in forum General (Petrol, Gas, Ethanol)
    Last Post: April 2nd, 2010, 05:58 AM
  2. Can't Validate ETC PIDs
    By DrX in forum General
    Last Post: January 18th, 2010, 02:52 PM
  3. Can't get GM.AFR_B to validate in E67
    By JAY4SPEED in forum E37, E38 & E67 PFI ECM's
    Last Post: August 22nd, 2008, 05:55 AM
  4. Validate Modules?
    By Cougar281 in forum General
    Last Post: July 24th, 2007, 10:22 AM
  5. Can't validate RAFNG pid
    Last Post: June 27th, 2006, 01:46 AM
