Results 1 to 10 of 11
Thread: CANT FIND VERSION 7.3 "DOC" FILE TO SAVE IN MY LAP
    Jun 2005
    Default CANT FIND VERSION 7.3 "DOC" FILE TO SAVE IN MY LAP
    I downloaded the 7.3 upgrade several times and the is no "DOC" file. The install instructions on the sight say to copy the new "DOC" file into the old one. Where is the new one? Any help would be great.
    '71 chevelle
    Twin turbo ls1
    1000 HP 93 octane street car!
    96 lb injectors
    Joe, that page only has the 7.2 docs 8)
    The 7.3 docs are actually here:
    http://www.efilive.com/downloads/downloads_730.html
    They are named differently (they have an extra "3" in the filename. If you want EFILive to bring them up automatically when you click on the Help toolbar icon, then you need to remove the "3" from the file name. That will of course require that you delete/rename both V7.2 documents that might already be in your Program Files\EFILive\V7\Doc folder.
    i.e. the existing V7.2 docs are called:
    EFILiveV7Scan.pdf
    EFILiveV7Tune.pdf
    The downloadable V7.3 docs are called:
    EFILiveV73Scan.pdf
    EFILiveV73Tune.pdf
    The name are different so that both sets of docs can be kept in that folder just in case you need to refer to the old docs to clear up any confusion about features that may have changed between 7.2 and 7.3
    The new software will be changed to look for the V7.3 docs in the next release.
    Jun 2005
    7. Copy all files from the Doc folder to
    This is the 7.3 file I cannot find to copy the files over?????
    '71 chevelle
    Twin turbo ls1
    96 lb injectors
    Jun 2005
    O.K I deleted the files EFILiveV7Scan.pdf and EFILiveV7Tune.pdf
    in Program Files\EFILive\V7\Doc. per your instructions. Now I need those EFILiveV73Scan.pdf and EFILiveV73Tune.pdf you are talking about.
    Where are the new "3" files? I cannot find them in my unzipped zip file? Are they in there? I don't see them. As soon I can find those, I am done with the 7.3 upgrade. Let me know. Thanks.
    '71 chevelle
    Twin turbo ls1
    96 lb injectors
    EFILiveV7Scan.pdf
    EFILiveV7Tune.pdf
    EFILiveV73Scan.pdf
    EFILiveV73Tune.pdf
    Jun 2005
    I am sorry, but I don't get it? I do not see any file named :
    EFILiveV73Scan.pdf
    EFILiveV73Tune.pdf
    I am sorry if I appear to be an idiot, but I loaded The program, unzipped it, leaded all files that matched the names in the instructions, but I cannot locate the files above to load into the DOC file on the laptop.
    '71 chevelle
    Twin turbo ls1
    96 lb injectors
    Sep 2003
    1. Click the link http://www.efilive.com/downloads/downloads_730.html
    2. Read the page and dload the user manuals located midway on the page
    3. Remove the 3 from the filename and put it in the appropriate directory (Program Files\EFILive\V7\Doc)
    EFILive - The Single version of the Truth
    Larry - HumpinSS
    Jun 2005
    Besides the above post, I get a message popping up that tells me that "C:/My Documents/EFILive/V7/User Configuration/cal_adjust.txt
    What does this mean? I have no apparent problems?
    '71 chevelle
    Twin turbo ls1
    96 lb injectors
    Jun 2005
    You mean that is just the user documents? Geez, I am making all that fuss for nothing!
    '71 chevelle
    Twin turbo ls1
    96 lb injectors
  1. what table controls start up decay speed? "how fast it decays out"
    Last Post: March 20th, 2009, 12:10 AM
  2. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  3. "PCM is in an Unkown State" & "Reflash Failed"
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2006, 12:53 PM
  4. 97 PCM "Bad bin file format"?
    By caver in forum General (Petrol, Gas, Ethanol)
    Last Post: October 19th, 2005, 12:13 AM
