Results 1 to 4 of 4
Thread: Need help with start up tune
    May 2007
    Default Need help with start up tune
    My Nova project is getting close and I am starting to work on the start up tune for it. I am going to run speed density and most likely a cos 3 or 5. Not sure which will be the better for my set up.
    this is a 11.73/1 347 ls1 , I will be using a 6.0 truck intake(78 mm tb) to start with . the heads are 5.3 heads milled to 54 cc chambers and ported to flow peak of 283 @.550 lift with nice mid lift numbers. Headers are going to be 1 3/4 stepped to 1 7/8 fenderwell exit . I am not using o2 sensors on this set up either as it is a race car. doesnt need to have good gas milage to move around and load on a trailer.
    the ecm is out of a 2001 6.0 truck. I am going to start with my timing curve out of my T/A as I run peak timing at 26 deg under WOT and I may add a splash of race fuel just to start it and make sure its safe.
    The cam is a 239/243 .612/.612 lift 112 lsa on a 110 cl.
    Dynamic Compression is at 8.5/1
    What I need help with is getting a tune in it to make sure it will safely crank and break in. I can tune it in from there just dont want to do much guessing on the start up tune. Any help or tips would be great.
    2000 NBM trans am.
    427 Dart ship block,Lme ported Ls7 heads 12.5 compression
    246/262 .730/.712 112+4 low lash solid roller
    Rmvb 4l80 with transbrake, 8" FTI converter
    12 bolt Moser rear end with 4.10 gears
    May 2007
    I guess i will figure it out
    2000 NBM trans am.
    Jul 2007
    I sent you a PM. Also, I will be testing the COS5 on Tue on the dyno, possibly the track if I like what I see. I have my car well tuned SD, so it will interesting to see how the TPS vs RPM helps. I like the fact that you get a steady RPM vs TPS ref for tuning w/COS5.
    Hang in there, I'm sure someone who has used COS5 realtime SD will send you data.
    07 Silverado DMax Classic
    02 Z06 LS3 416, 805rwhp, TFS245, Wiseco, Callies Crank/Rods, Iskendarian Lifters, Crower Rockers, FAST102/90, ATI Damper, 1-7/8 Kook's LT, QkTime Shield,Tolle-Fab 8pt
    Old Engine: 1/4mile = 9.6/146 New Engine:?
    EFI Live Tune/Scan v7.5.27, EFI Live Scan and Tune v8.2.23, build 276, BootBlock 2.07.06, FirmWare 2.07.52, 512K RoadRunner (12.14.R), Innovate Serial LC2x2
    COS5/12212156 For 2002 Z06 Manual Vette
    May 2007
    Thanks, I sent you a pm back. I may have to reduce the ve table some since you have a bigger motor but it gives me some things to work off of.
    2000 NBM trans am.
  1. Start in second gear tune.
    By duramaximizer in forum Allison 5 & 6 Speed
    Last Post: April 25th, 2009, 07:21 PM
  2. No start tune?
    By DmaxHawk in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 11th, 2009, 08:53 PM
  3. Start up tune for KB Supercharger
    By Gordy M in forum Gen III V8 Specific
    Last Post: May 20th, 2008, 03:21 AM
  4. What's wrong with my tune, car wont' even start.
    By farmdawg in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: March 17th, 2008, 05:27 PM
  5. Help with start up tune...Please take a look at my tune
    By ThirdGenLS1 in forum Gen III V8 Specific
    Last Post: August 24th, 2007, 12:36 AM
