Results 1 to 8 of 8
Thread: problem lowering throttle idle for ckp relearn
    Senior Member mtnman's Avatar
    Sep 2005
    Default problem lowering throttle idle for ckp relearn
    I was trying to do the ckp relearn and I followed the instructions for lowering the idle, but I am unable to get the throttle idle below 10.
    It briefly goes to 9, but not long enough for the relearn to take place.
    The instructions say to raise the rpms to 4k or above for 4-5 seconds, then the throttle should drop below 10, but it doesnt, it drops to 10 and stays there.
    Anybody else have this problem?
    Sep 2003
    try revving to 4500-4800
    EFILive - The Single version of the Truth
    Larry - HumpinSS
    We made the throttle max too low for some ETC vehicles. We "assumed" that 10% throttle is well above idle, I guess it is not on your vehicle.
    The next software release will not restrict the CKP process based on throttle position.
    That should be available this weekend.
    Sep 2005
    Where do I go to download the updates?
    Do I download the "current" EFILIve V7 at
    http://www.efilive.com/downloads/index.html
    Sep 2003
    try hitting f3 even if the cells are red
    Larry - HumpinSS
    Quote Originally Posted by mtnman
    The latest release is here
    http://www.efilive.com/downloads/downloads_730.html
    but that still has the 10% throttle restriction.
    If DD is correct (I haven't checked for sure yet), then you can still start the test by pressing F3 - even if the TPS is >10%.
    Sep 2005
    How long does the process take after pressing the button or F3? Should it take 30 seconds, 5 seconds?
    I tried pushing F3 even when it had been red, then i viewed the dtc list and there were about 4 faults that the ckp relearn had failed.
    Check out this list of criteria:
    http://www.efilive.com/forum/viewtop...=1988&start=10
    After you press the F3 key, you must bring the engine up to 4500-5000 (varies depending on model-year) withi 5 seconds. At around 4500 rpm you should feel the momentary hesitation.
    The latest version of EFILive V7.3 allows 10 seconds.
  1. im having a problem with the crank relearn
    By whackem04 in forum General
    Last Post: December 17th, 2009, 05:53 AM
  2. 02 corvette throttle relearn?
    By ChucksZ06 in forum Gen III V8 Specific
    Last Post: April 30th, 2009, 02:18 AM
  3. Help!! No idle and can't perform crank relearn
    By onegonewild in forum Gen III V8 Specific
    Last Post: October 16th, 2008, 03:42 PM
  4. Problem Performing Crank Relearn!!!!!! I need help quick
    By 01Blackerado in forum Gen III V8 Specific
    Last Post: October 24th, 2007, 08:15 AM
  5. Idle Relearn?
    By RevGTO in forum General (Petrol, Gas, Ethanol)
    Last Post: January 22nd, 2007, 07:21 PM
