Question pertains to the advantages and disadvantages of calibrating the MAF using CYLAIR DMA vs just using SAE MAF.
If I know my MAF Frequency (hz) and I know my Air flow rate from my MAF sensor (SAE. MAF grams) why do most suggest instead calibrating it to CYLAIR DMA or as some have suggested to DYNCYLAIR DMA (dynamic)?
While I generally understand that this is to compare your MAF flow to your actual 'calculated' flow..Why is it improper to actually compare what your MAF is flowing vs the frequency? If the contribution of the MAF flow and its interaction with the VE table derived airflow is ultimately the sum of the two...Why measure the MAF flow against that sum?
To clarify, can I just use MAF frequency and SAE MAF, as my flow calibration?
