Page 11 of 11 FirstFirst ... 91011
Results 101 to 106 of 106
Thread: Tuning the transient parameters
  1. #101
    Lifetime Member MICK's Avatar
    Mar 2005
    Default Hummm
    Highlander,
    I have given Mick 2 bin files to play with. You can open bin files with any software but once you save them they become encrypted.
    TC has a hidden test feature in it's winflash software that allows read and write of bins.
    If you split a bin down into it's segments and use 7zip on them then they become compatible with tis to web.
    In a nut shell, there it is for you.
    Mick
    Rev it up, Drop the clutch, See what happens?
  2. #102
    Mick, more good information as always. Im trying to figure out how I can get enough time and knowledge to hack the infernal P10 PCM. Shares a bunch of code with LS1 and 98-02 4cyl PCMs I know, I just need a few more parameters and Id be a happy man. If it means hacking it, I cant wait to learn. Might take a few years but I can wait lol
    And just saw that TC released P10 support recently, wonder if I can play around with it and see what params they have...
  3. #103
    Junior Member Frost's Avatar
    Nov 2009
    Quote Originally Posted by MICK View Post
    Highlander,
    Mick
    For GenIII, alternately, you can remove the flash chip and get a binary dump from it with a benchtop programmer as well.
    Assuming this is OK to post here... here is a binary from a 2002 A4 F-body that I yanked with a flash programmer and reordered the data into the format that our platforms (little endian vs. big) are looking for.
  4. #104
    Hi Frost, welcome to the forum...
  5. #105
    Nov 2009
    Thanks Joecar!
  6. #106
    Jul 2003
    And Thank you Frost... you've got mail.
    Anyways... you will find a lot of wealth of information. Main thing about EFI over HPT is Serial Wideband. It really makes a hell of a difference.
  1. Transient Fuelling Pid
    By 5.7ute in forum Tips and tricks
    Last Post: April 8th, 2012, 11:35 AM
  2. What are the transient tables?
    Last Post: November 16th, 2009, 04:33 AM
  3. Transient fuelling????
    By hquick in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: September 25th, 2008, 06:15 PM
  4. B1053 Transient table????
    By rcr1978 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 28th, 2008, 05:01 AM
  5. Missing parameters in tuning tool?
    By QUICKSILVER2002 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 17th, 2006, 03:03 PM
