Page 1 of 10 123 ... LastLast
Results 1 to 10 of 106
Thread: Tuning the transient parameters
    Jan 2007
    Default Tuning the transient parameters
    Ok guys....couldn't wait any longer so I decided to make some adjustments to my B9000 table before heading home from work.
    I upped the 90 & 100 kpa columns by 10%. After a little driving I noticed a small decrease in the lean tip-in spike so I pulled over and raised it another 10%.
    Another drive and then another 5% as well as lifting the 80 & 70 rows 5%.
    If there's still any lean tip in...it's negligible....but being the perfectionist (addict ) I am....I'll keep working on it.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Oct 2006
    Thats good news. Any relationship with the BENS & the amount you needed to modify the table? (Just thinking ahead for the roadrunner.)
    The Tremor at AIR
    Jan 2007
    No idea Mick . Lol!
    I'm sending you my tune and logs....you can take a peek.
    Howard
    DUCT TAPE.
    Oct 2006
    No worries. I will have a look tomorrow after I upgrade the work PC.
    The Tremor at AIR
    Lifetime Member Aloicious's Avatar
    Nov 2007
    Quote Originally Posted by hquick View Post
    GREAT! I'm stoked, I'm going to try this out as well. I have the lean tip in as well as a slight rich decel issue I'd like to try working on with this (wall wetting table I'm thinking) as nothing else seems to fix it.
    Howard, did you leave all the other calibration values the same as the initial file? (i.e. you only altered the b9000 by increasing the column values, no other tables?) I'd be interested in seeing your tune once you iron it out.
    good job!
    1996 c1500 gen1e 5.7L - the "LS31", 24x CNP, LS2 coils, modified T56, 12200411PCM running COS3, zz4 cam, custom MPFI, etc. coming soon: Twin Turbos
    Jan 2007
    Send me your email address and I'll send it to you right now.
    I had rich decel also..and it's gone.
    I still need to do alot of testing and tuning. This was a 'rough' test....but seemed to head the right direction.
    Howard
    DUCT TAPE.
    Nov 2007
    I'll PM you. did you adjust the wall wetting tables for the rich decel?
    EDIT- I see b9000 IS a wall wetting table. DUH. I thought it was under the throttle stop section. how did you work on the rich decel problem you had?
    Jan 2007
    Rich decel went away with the lean tip in.
    Howard
    DUCT TAPE.
    Jan 2007
    Current log and tune
    Howard
    DUCT TAPE.
    Aug 2006
    First off For getting these going! HQuick, I made an ~30% increase to the 80+ kPa columns, and 10% everywhere else. Still some fine tuning to do, very happy with the results so far.
  1. Transient Fuelling Pid
    By 5.7ute in forum Tips and tricks
    Last Post: April 8th, 2012, 11:35 AM
  2. What are the transient tables?
    Last Post: November 16th, 2009, 04:33 AM
  3. Transient fuelling????
    By hquick in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: September 25th, 2008, 06:15 PM
  4. B1053 Transient table????
    By rcr1978 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 28th, 2008, 05:01 AM
  5. Missing parameters in tuning tool?
    By QUICKSILVER2002 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 17th, 2006, 03:03 PM
