Page 8 of 12 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 115
Thread: Expanded Support for Transient Fuel.
  1. #71
    Lifetime Member Whippled 496's Avatar
    Sep 2006
    Just me again....checking in....please go on about your business....
    2014 GMC 2500HD RCLB SLE
    LML / Allison
  2. #72
    Sep 2006
    Hey look who it is....its the jerk-off with the 1mb PCM....LOL. Sorry, just browsing and checking in.
    LML / Allison
  3. #73
    Lifetime Member Aloicious's Avatar
    Nov 2007
    Quote Originally Posted by Whippled 496 View Post
    jerk off!
    1996 c1500 gen1e 5.7L - the "LS31", 24x CNP, LS2 coils, modified T56, 12200411PCM running COS3, zz4 cam, custom MPFI, etc. coming soon: Twin Turbos
  4. #74
    Sep 2006
    Suprise!!! its me!!
    Bye.
    LML / Allison
  5. #75
    Nov 2006
    I still don`t get the CAX files,
    do they create new tables in the OS?
    How are they viewed/edited?
    LC-1 WBO2
  6. #76
    Jan 2007
    Here's a couple of screenshots.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
  7. #77
    They don't create new tables, they simply provide a pointer or offset into the binary and a definition of what the bits/bytes mean and text labels for displaying in the tunetool tree...
    the cax files define what a region of "memory" means and the tunetool has functions built into it to interpret the cax definition to know how to display/edit the data in that region.
  8. #78
    Sep 2006
    HQUICK..........I hate you.
    LML / Allison
  9. #79
    Lifetime Member MICK's Avatar
    Mar 2005
    Default Hummmmm
    I admire your patients and perseverance. You have good humor about it all!!!
    Also had a look at your video's on your web, pretty cool site.
    Had another look around your operating system and I will put a little more time on it and see how I go, not making any promises.
    Mick
    Rev it up, Drop the clutch, See what happens?
  10. #80
    Aug 2005
    Quote Originally Posted by MICK View Post
    Mick
    I'd be glad to help incentivize you.
    Had a chance to adjust the use these parameters to fix a pretty bad lean spike tip-in on a MAF'd truck (go figure) on Friday. Worked beautifully.
  1. Transient Fuelling Pid
    By 5.7ute in forum Tips and tricks
    Last Post: April 8th, 2012, 11:35 AM
  2. torque based fuel transient
    By SGFastMax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 11th, 2010, 03:53 PM
  3. What are the transient tables?
    Last Post: November 16th, 2009, 04:33 AM
  4. Transient fuelling????
    By hquick in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: September 25th, 2008, 06:15 PM
  5. Transient Fuel with 1999 LS1?
    By Tomato in forum Gen III V8 Specific
    Last Post: June 16th, 2008, 05:28 AM
