Page 9 of 12 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 115
Thread: Expanded Support for Transient Fuel.
  1. #81
    Jan 2007
    What adjustments did you make Justin?
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
  2. #82
    Lifetime Member Whippled 496's Avatar
    Sep 2006
    Quote Originally Posted by MICK View Post
    I admire your patients and perseverance. You have good humor about it all!!!
    Also had a look at your video's on your web, pretty cool site.
    Had another look around your operating system and I will put a little more time on it and see how I go, not making any promises.
    Mick
    Mick,
    This is your personal time and I am in no way going to be impatient about something someone does not have to do. Sure, I wish that EFILive had the time to release an update with the transient fueling built in but they have already addressed this as something they will not do. I come in to the CAX section from time to time just to see where we are with this thing. I really do appreciate the time you contribute to helping others and if there is something you need from me to help you out....just say the word! Otherwise I will continue to swing in and say "hello!"
    Jimmie
    2014 GMC 2500HD RCLB SLE
    LML / Allison
  3. #83
    Lifetime Member MICK's Avatar
    Mar 2005
    Default Hummm
    Hay Jimmie,
    There is something you can do for me to help out.
    I added a Lean Cruise patch to a .cax file for your operating system base: 12593058.
    I renamed the attached file to your custom operating system # 03190003.
    You want to test out the operation of the Lean Cruise?
    I droped a couple other tables in there while I was looking for the Transient Impact Factor Table. Don't play with these as this is just where I left off and I don't know what they are yet.
    I will have a look around again and see if I can pinpoint the Impact factor table.
    Mick
    Rev it up, Drop the clutch, See what happens?
  4. #84
    Sep 2006
    Hay Jimmie,
    Mick
    Awesome Mick!!! I just wish I would have popped in here earlier and I could have tried this out today..... I will load it up tomorrow and it give it a whirl. Thanks again!
    Jimmie
    LML / Allison
  5. #85
    Sep 2006
    I think we got a winner Mick. I set up what i think is the right way to enable LC and it seemed to do what it was supposed to.
    B9011 = Enabled
    B3634 = 120 seconds
    B3635 = 20 seconds
    B3636 = 45 mph
    B3637 = 30 mph
    B3638 = 1.0
    I generically populated some data in B3639 from 1600 rpm - 2400 rpm (which unfortunately is my cruising RPM) and from 0.24 g/cl - 0.72 g/cl.
    I left B3646 all zero's up until 158*F then all "1's" from there up.
    When all the filters were satisfied, it leaned out like it was supposed to. I think you may be onto something MICK.....is the wall wetter next?
    LML / Allison
  6. #86
    Mar 2005
    Default Hummm
    Yeah that might be the plan, I will keep looking around for you and see how I go.
    Hang in there, you just never know?
    Mick
  7. #87
    Sep 2006
    Just checkin to see if any stuff was floating around yet.
    LML / Allison
  8. #88
    I finally did it!, transient fuel has been added to the LS1 calibrations for all OS's from 1998 - 2008, these will be in the next update.
  9. #89
    Aug 2005
    Ross, you ROCK!
  10. #90
    The setup on the 2003+ was quite different to 1998-2002 due to the Ethanol fuel options. Hopefully I added enough to make it do what you guys need.
  1. Transient Fuelling Pid
    By 5.7ute in forum Tips and tricks
    Last Post: April 8th, 2012, 11:35 AM
  2. torque based fuel transient
    By SGFastMax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 11th, 2010, 03:53 PM
  3. What are the transient tables?
    Last Post: November 16th, 2009, 04:33 AM
  4. Transient fuelling????
    By hquick in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: September 25th, 2008, 06:15 PM
  5. Transient Fuel with 1999 LS1?
    By Tomato in forum Gen III V8 Specific
    Last Post: June 16th, 2008, 05:28 AM
