What adjustments did you make Justin?
Howard
DUCT TAPE.
98 K1500 'HOLDEN' Suburban.
Mick,
This is your personal time and I am in no way going to be impatient about something someone does not have to do. Sure, I wish that EFILive had the time to release an update with the transient fueling built in but they have already addressed this as something they will not do. I come in to the CAX section from time to time just to see where we are with this thing. I really do appreciate the time you contribute to helping others and if there is something you need from me to help you out....just say the word! Otherwise I will continue to swing in and say "hello!"
Jimmie
2014 GMC 2500HD RCLB SLE
LML / Allison
Hay Jimmie,
There is something you can do for me to help out.
I added a Lean Cruise patch to a .cax file for your operating system base: 12593058.
I renamed the attached file to your custom operating system # 03190003.
You want to test out the operation of the Lean Cruise?
I droped a couple other tables in there while I was looking for the Transient Impact Factor Table. Don't play with these as this is just where I left off and I don't know what they are yet.
I will have a look around again and see if I can pinpoint the Impact factor table.
Mick
Rev it up, Drop the clutch, See what happens?
I think we got a winner Mick. I set up what i think is the right way to enable LC and it seemed to do what it was supposed to.
B9011 = Enabled
B3634 = 120 seconds
B3635 = 20 seconds
B3636 = 45 mph
B3637 = 30 mph
B3638 = 1.0
I generically populated some data in B3639 from 1600 rpm - 2400 rpm (which unfortunately is my cruising RPM) and from 0.24 g/cl - 0.72 g/cl.
I left B3646 all zero's up until 158*F then all "1's" from there up.
When all the filters were satisfied, it leaned out like it was supposed to. I think you may be onto something MICK.....is the wall wetter next?
LML / Allison
Yeah that might be the plan, I will keep looking around for you and see how I go.
Hang in there, you just never know?
Mick
Just checkin to see if any stuff was floating around yet.
LML / Allison
I finally did it!, transient fuel has been added to the LS1 calibrations for all OS's from 1998 - 2008, these will be in the next update.
Ross, you ROCK!
The setup on the 2003+ was quite different to 1998-2002 due to the Ethanol fuel options. Hopefully I added enough to make it do what you guys need.
