Page 3 of 12 FirstFirst 12345 ... LastLast
Results 21 to 30 of 115
Thread: Expanded Support for Transient Fuel.
  1. #21
    Mick,
    I reread COS tutorial page 4...
    I diffed all the cax files in every direction/dimension/permutation, and these are the 4 base cax files from which all others will be copied (see attached)... I edited the comment showing which OS's each file supports.
    I edited out any non-significant differences (i.e. whitespace, description text reminders) so that all 4 files have uniform format... i.e. any differences are significant.
    I am almost ready to merge in the lean cruise stuff...
  2. #22
    Default 1208322 is base for 01270003
    Mick,
    In file 12208322.cax, have I gotten B9000 and B9001 correct -->
    see attached diff report of 12208322.cax (left side) with 01270003.cax (right side) -->
    look at lines 364/367 and 402/405 --->
    sanity check: which one is correct...?
    Thanks,
    Joe
  3. #23
    Lifetime Member MICK's Avatar
    Mar 2005
    Default Hummm
    Joe,
    I like your work!!! I was spending some time today doing the same thing.
    That looks good to if you want to add the lean cruise code.
    Only thing is people might be getting a little confused with which files are the most updated. I would like to tidy up the posted files here there and everywhere. Maybe even put them in there own thread and lock it. Then when we have updates to the files you can handle the posting of the updates and keep them in one place.
    Do you have admin access to do this on the forum?
    I also want to collaborate our efforts if your interested, I will keep looking into new operating systems and look at fixing parameter errors, you can handle the files and be the second set of eyes and have some fun on the way.
    I was also wondering if Mick 5.7 Ute would be interested in posting his mods to the cal_link.txt file to enable the tracking of these Transient Parameters and supply his input to get the real-time going?
    This is my definition of TEAM.
    Together Everyone Achieves More.
    No Bad Apples.....
    Rev it up, Drop the clutch, See what happens?
  4. #24
    I'll make a new sticky/locked thread that will contain the sequence of updates.
  5. #25
    Jan 2007
    Good idea Mick
    Well done on the 'sticky' thing Joe. With you two guys together....this will be a very interesting project.
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
  6. #26
    Lifetime Member Whippled 496's Avatar
    Sep 2006
    Anything for COS3 03190003?
    2014 GMC 2500HD RCLB SLE
    LML / Allison
  7. #27
    No not yet.
  8. #28
    Mar 2005
    Default Hummm
    Quote Originally Posted by Whippled 496 View Post
    Whippled 496,
    Could you post your tune in this thread and I will check out the possibilities. If it looks good I will put something together and forward it to Joe to review.
    Cheers
    Mick
  9. #29
    Aug 2005
    Quote Originally Posted by MICK View Post
    Whippled 496,
    Cheers
    Mick
    Mick,
    Here's a stock tune with that comparable OS.
    Justin
  10. #30
    Sep 2006
    Thanks Mick and Justin....here is one of my recent tunes i was working on.
    LML / Allison
  1. Transient Fuelling Pid
    By 5.7ute in forum Tips and tricks
    Last Post: April 8th, 2012, 10:35 AM
  2. torque based fuel transient
    By SGFastMax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 11th, 2010, 02:53 PM
  3. What are the transient tables?
    By LBZoom in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 16th, 2009, 03:33 AM
  4. Transient fuelling????
    By hquick in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: September 25th, 2008, 05:15 PM
  5. Transient Fuel with 1999 LS1?
    By Tomato in forum Gen III V8 Specific
    Last Post: June 16th, 2008, 04:28 AM
