Results 1 to 10 of 17
Thread: V2 Black Box data logging*vortec pid's*
    Aug 2008
    Default V2 Black Box data logging*vortec pid's*
    When I want to do some data logging with my V2 and no laptop I don't see Vortec listed in the PID list. Is Vortec not available? Do I need to add a Vortec file in the config files on the EFI explorer? I'm stuck......
    Aug 2008
    No-one :(
    I pm'd Paul.
    You can just create a new entry in the Options.ini file and set up your own PIDs for the vortec.
    Until I create a Vortec.pmm file, you shoul dbe able to use the LS1B.pmm file.
    That will mean some PIDs may or may not be supported - you'll need to do a validate PIDs on the laptop based scan tool to know which PIDs are valid for the Vortec.
    Aug 2008
    Ok, 16 of the 18 Pids are showing that they are valid. The unlucky one's are...EOPS & AFR :(
    Aug 2008
    YES, I finally got it to work I'm a data logging "SOB" now. WooHoo!!! Thanks alot Blacky-(Paul)
    JB
    Member Treurentner's Avatar
    Nov 2005
    Hi,
    can you post your ini file to see what pids are working (I have a S15 SLT -4.3 Vortec)? I would be happy if I can use BBL on that car too
    Many thanks in advance!
    Marco
    GAMEOVER, did you get AFR to BBLog...?
    Aug 2008
    No Joe, That's one of the pids that won't work. When I data log using my V2 & laptop It will work but I've got to use the AFR PID from the LS2 B. So in the meantime(while I data log laptopless) I'm using my LC-1 for my AFR but it's been acting real erratic lately :( don't know what's going on with it!!!
    JB
    Quote Originally Posted by GAMEOVER View Post
    JB
    Are you using the serial/digital AFR signal or the analog AFR signal from the LC-1?
  1. Vortec 350/ Black box
    By 99TransAmls16spd in forum Vortec V6/V8 Specific
    Last Post: December 11th, 2009, 06:15 PM
  2. Black Box Logging
    By L31Sleeper in forum Vortec V6/V8 Specific
    Last Post: June 22nd, 2009, 03:16 AM
  3. V2 Black Box Logging
    By Blacky in forum FlashScan V2
    Last Post: November 4th, 2007, 10:51 PM
  4. Black Box Logging
    By C3vette75 in forum General
    Last Post: June 19th, 2005, 01:07 AM
  5. Retrieving Black Box Data
    By Ninety8C5 in forum General
    Last Post: January 17th, 2005, 11:09 AM
