Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Help, no start!
  1. #11
    Jul 2007
    I thought disconnecting the batteries was a big no-no if there was a problem, and that it made the ecm impossible to recover. Isn't there some sort of warning against it in the manual?
  2. #12
    The full flash "do not pull battery power" warning is for older style PCMs that completely erase their memory when being full flashed. The new style PCMs/ECMs retain some "sanity" even when being full flashed so that if power is disconnected during a full flash then they are 100% recoverable.
    Just off the top of my head:
    PCMs that you should never disconnect power from if a full flash fails:
    • LS1 97/98
    • LS1 99+
    • LB7
    • 4CylA
    • 4CylB
    PCM's that you can remove power from during a full flash:
    • E38
    • E40
    • E67
    • P12
    • LLY
    • ALLISON 5spd
    We should make up a list of which type of PCM is in which category (GMPX Revised the list).
    Quote Originally Posted by Sparky8370 View Post
    Last edited by GMPX; October 1st, 2008 at 06:29 PM. Reason: Revised controller list
  3. #13
    Jul 2007
    Thanks for that, because my pcm is on the no-no list. Just my luck I would have remembered reading this thread and un-plugged it. Actually, I would probably come crying to here before I did anything that drastic anyway.
  1. COS and no start
    By turbogtu in forum General
    Last Post: September 15th, 2009, 02:27 PM
  2. Cold start perfect, Warm start flares high
    By samh_08 in forum Gen III V8 Specific
    Last Post: May 12th, 2009, 09:36 PM
  3. Cold start great but warm start sucks."Idle
    By mvvette97 in forum Gen III V8 Specific
    Last Post: October 26th, 2008, 12:22 AM
  4. Where to Start on an LB7?
    By LBZoom in forum Duramax LB7
    Last Post: October 7th, 2008, 07:30 AM
  5. Where do I start?................
    By FreddyG in forum General (Petrol, Gas, Ethanol)
    Last Post: June 2nd, 2006, 08:08 AM
