Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: PCM 12593358 Cax File Check
  1. #21
    Quote Originally Posted by MICK View Post
    Joe,
    That's how I disabled those 2 parameters as they did not look right, I think?...... I need to go over this one and 12205074 to tidy them up. I'm going to look at the scalers a little and fine tune them, they need to be a little more consistent. I am on it.
    Mick
    Mick,
    Ok I was sanity checking just in case the dots had crept in
    (I have plenty of experience in the field of characters creeping in... ).
    Joe
  2. #22
    Lifetime Member MICK's Avatar
    Mar 2005
    Default Hummmm
    Joe,
    Over the weekend I did some work on the base files improving the Factor Scalers, including Imperial Values and generally fixing a few errors. I found another supported OS. Can you have a look over these files and add the LC. If your happy you can update the files thread.
    There is one more OS I see that I could support in the 2001, 2002 family, OS: 12209203 but I don't have a base tune file to work off so if any one has one it would be cool if you could post it.
    I had a good look at the 2003 family of OS this weekend, starting with OS: 12593058. These jumped up in file size from 512kb to 708kb and the code has moved around quite a bit so I will need to change my plan of attack here. I found a few tables that are possibilities but really need to start working in binary format to make some break through. It would not surprise me if the tables changed in there appearance and there were a couple more that are included in the code.
    This is the direction that I would like to head in, will keep chipping away at it.
    Mick
    Rev it up, Drop the clutch, See what happens?
  3. #23
    Mick,
    Ok, I'll go thru those and I'll integrate and post.
    Thanks,
    Joe
  4. #24
    Ok, I edited/merged lean cruise into those, and I made all files have uniform format (the numeric content did not change, of course)...
    I'll post these updates to the cax updates thread.
    Mick,
    I made the files uniform since this makes it easy to see the numerical differences;
    if these are ok, then please use these for any further work.
    showthread.php?p=79912#post79912
    Thanks,
    Joe
  1. check out my log
    By JOHNGEAR in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 21st, 2009, 01:17 PM
  2. check out my VE
    By nchristian in forum Gen III V8 Specific
    Last Post: June 17th, 2009, 04:01 PM
  3. Check this out! help!!
    By 05duramonster in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 4th, 2009, 12:39 PM
  4. .Tun file check?
    By Aloicious in forum Vortec V6/V8 Specific
    Last Post: January 18th, 2008, 10:51 AM
  5. Stock Tune for 12593358
    By superls1 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 1st, 2005, 05:22 PM
